[DesignModeler] Help needed. Add Frozen doesn't work? |
April 18, 2012, 07:53 |
Muhammad K
Hi everyone!
I'm struggling to get a perfect mesh for my simulation, which is simulating flow around a square building inside a wind tunnel,using CFX. This is my model: -it's basically a box within a box. -The small box (the building), I used add frozen - While the big box, I used add material http://img404.imageshack.us/img404/6016/48680222.jpg I expected Ansys meshing to exclude the interior part of the building, and only mesh the surrounding. But as shown in the photo below, its meshes everything. http://img853.imageshack.us/img853/386/88239343.jpg I had also turned on inflation, I am planning to put inflation ini the surrounding of the building later. Can anyone point out what went wrong? Cheers! |
April 18, 2012, 09:22 |
Ghazlani M. Ali
Rep Power: 28 |
because you mentioned add frozen for the small box, not sure how. anyway here is what i would have done:
Draw you building first. Add the big box by drawing a square and extruding it. there you will select add frozen (while drawing the big box).then you will have to do a Boolean operation to subtract the small building You can split you geometry for symmetry if you want less computational time and less time for mesh generation. Can you attach your project ? |
April 18, 2012, 09:45 |
Muhammad K
Hi Ali
Thanks for your response What I have done is, I have created two boxes using the create>primitives>box and arranging its positions by redefining their xyz coordinates. I have uploaded the file for you here http://www.4shared.com/zip/rJBMZlHO/New_folder.html Thanks! |
April 18, 2012, 18:39 |
Muhammad K
Got it. Thanks mate
MuhammadK |
design modeler, meshing issues |
how to add OpenFoam in module environment | smpark | OpenFOAM | 4 | May 12, 2011 15:00 |
Transient post-processing, Time averaged pressure work | Turbomachine | CFX | 1 | January 3, 2011 18:01 |
work station power needed | Greg | Main CFD Forum | 4 | September 16, 2008 04:29 |
Project Advice Needed | Kapil | Main CFD Forum | 6 | September 4, 2006 09:00 |
Consultant needed to optimize an oblique diffuser. | Paul | Main CFD Forum | 0 | March 24, 2004 17:59 |
