[ANSYS Meshing] ANSYS Meshing vs. ICEM
Old   April 19, 2012, 06:37
Default ANSYS Meshing vs. ICEM
Helen
oborona is on a distinguished road
Hello.
As I know GAMBIT is no longer developed. The last version is GAMBIT 2.4.
So what you can recommend as alternative program for the meshing? There are ANSYS Meshing and ICEM in the ANSYS package. Which of them is more developed and easy-to-use?
I'll be thankful for yours comments
oborona is offline   Reply With Quote
Old   April 19, 2012, 11:14
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
I would recommend ICEM as it has very strong HEXA, prsim and tetra meshing methods. If you combine the ICEM with Tgrid then you do not need any other mesher at all.
On the other hand ANSYS meshing is easy to use and still passing from development phase. ANSYS meshing is built around the techniques from gambit, cfx mesh, ICEM and Tgrid. Its main emphasis is on the the more automatic use and uses the inflation along with tetra in the rest of domain. HEXA is really hard to create in ANSYS meshing.
AM has some advantages as compared to ICEM. That is the cutcell algorithm.
Far is offline   Reply With Quote
Old   April 19, 2012, 11:28
Helen
Thank you very much. Your information is very useful for me )))
[ANSYS Meshing] ANSYS Meshing hangs at "Preparing to model boundary for part" jonny_b ANSYS Meshing & Geometry 12 June 12, 2012 01:55
Meshing a Mixing Plane using ICEM Will Anderson FLUENT 0 November 6, 2010 17:08
Ansys icem meshing of 2d hill syler3321 Main CFD Forum 0 June 27, 2010 21:38
ICEM meshing question gsbhatia89 ANSYS Meshing & Geometry 5 June 14, 2010 08:24
ICEM meshing question gsbhatia89 ANSYS Meshing & Geometry 0 June 10, 2010 08:29
