[ICEM] Volume mesh smoothing problem -DLR F6
Old   April 22, 2012, 11:47
Default Volume mesh smoothing problem -DLR F6
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Dear All
Right now I am practicing the prism-tetra part of ICEM. I am practicing ICEM 14 Workshop tutorials and geometry is DLR F6. I am sucessful in creating all steps e.g. shell meshing, volume mesh, prism, density box and smoothing tet-4 elements.
But I am stuck in volume meshing step for quad-4, penta-4, tri-3 and as per insturction I have applied smoothing twice but nothing happens. Any one can suggest me, where I am getting it wrong.
This is what I get:
This is what, should be achieved:
http://img515.imageshack.us/img515/5...rf6correct.png
Last edited by wyldckat; September 3, 2015 at 18:06. Reason: disabled embedded images
Far is offline   Reply With Quote
Old   April 23, 2012, 04:12
Christoph
energy382 is on a distinguished road
I can't see the attached pics!?
energy382 is offline   Reply With Quote
Old   April 23, 2012, 05:22
siw
Stuart
siw will become famous soon enough
The way I meshed this airfame (well the Common Research Model, but there very similar) was to first set-up the surface, volume and density region sizings based in the Octree criteria. Then I deleted the volume elements and smoothed the surface triangles until they would not improve any further (but I never used the laplace smoother as I found it made things worse). From that surface mesh I used the Delaunay (with TGlib/Use AF option switched on) to re-fill the volume. Again, I smoothed the volume tetras until no further improvment (no laplace again). Next I generated the prism layers to keep layering until it reached a smooth volume transition to the nearby tetras. The make a few floating prism layers and spliting/re-distributing does suit for this job I found. Then I smoothed it (sometimes freezing the penta elements). I did end up with pyramid elements due to the prism layers.
When smoothing the final mesh I freeze the pentas and aim to get a qualilty > 0.3. When I un-freezed the pentas I only smoothed up to 0.1 or it may have been lower.
I used ICEM v 13. As this was over 1 year ago so options my be different to v 14. I made posts with pictures asking for help with his mesh and PSYMN gave a loads of useful tips.
I biggest issue I found making a hybrid mesh was I could not get a fine resolution on the blunt trailing edges without getting a very high element total so I under resolved it with only 1 or 2 elements on the trailing edge height. Hexa does not have this issue.
siw is offline   Reply With Quote
Old   April 23, 2012, 06:27
Far
Sijal
Thanks for help. I shall try this method for this model as well.
But at the moment, I am following the tutorial and I assume that I should get what is depicted in tutorial.
I am going to attach the files with shell meshing and volume meshing with/without smoothing.
Thankyou again for your helpful hints and consideration.
Old   April 23, 2012, 06:28
Far
Sijal
Try again, may be at that time "imageshack server" was down.
Old   April 23, 2012, 06:31
Default ICEM 13 and ICEM 14
Far
Sijal
This may be due to that fact that I am practicing ICEM 14 tutorials on ICEM 13
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
[ICEM] Hexa Mesh Smoothing Jules ANSYS Meshing & Geometry 6 December 4, 2010 18:00
Ansys 12 Workbench problem when generating volume mesh Sveink ANSYS 5 January 6, 2010 03:17
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 10:09
