April 20, 2012, 01:18 |
Bad meshes around the joint
June
Rep Power: 14 |
Hi, Currently I am using CFX for solving laminar incompressible Navier-Stokes equation in a multiphase flow (Air/Water).
Bad meshes are generated around the water inlet to the solid disc. Mesh quality is bad in that the ratio of bad meshes is over 0.2 right now according to determinant 2 by 2 by 2. How can I enhance the quality for getting rid of these vectors around the inlet |
April 20, 2012, 17:14 |
Here is the ICEM CFD tin file
June
Rep Power: 14 |
Thanks for your help in advance.
After you rename it to water.tin then it's a tetin file due to the upload limitation? Best regards |
April 21, 2012, 02:24 |
Here are some links for video tutorials for similar cases.
http://www.youtube.com/watch?v=9Ojpf...wz-7pTbksd6nE= http://www.youtube.com/watch?v=Pe6Df...9wEAuT5erx1YE= |
April 21, 2012, 14:48 |
Thank you very much
June
Rep Power: 14 |
Thank you very much,
Currently, CFX solver is running very well. I am trying to replicate what you did like The injection hole should be projected to the output wall and make it splited by O-grid. I watched Youtube videos that you linked and it's fantastically helpful to me. Best regards Sincerely msormania |
Getting prism to inflate into mixed tet-hex meshes | Joe | CFX | 16 | October 10, 2011 07:06 |
[ICEM] how to create meshes of conformal nodes? | snailstb | ANSYS Meshing & Geometry | 2 | March 12, 2010 03:23 |
ICEM CFD dealing with bad meshes | James | Main CFD Forum | 3 | January 6, 2009 10:52 |
Problems of Duns Codes! | Martin J | Main CFD Forum | 8 | August 14, 2003 23:19 |
Large 3D tetrahedral meshes | Aldo Bonfiglioli | Main CFD Forum | 4 | August 27, 1999 03:33 |
