-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [DesignModeler] Help Please (http://www.cfd-online.com/Forums/ansys-meshing/100264-help-please.html)
VuiYee April 22, 2012 14:00
Help Please
I using Fluent to simulate my airfoil. My airfoil is transfer by excel to ANSYS-Workbench. I realize that the chord length of the airfoil can be change. Can anyone please guide me how to change? Please
Gweher April 22, 2012 23:58
You can use the option "parameter" in DM and edit it from the WB directly.
VuiYee April 23, 2012 05:05
Hi. Can you explain briefly?
Gweher April 23, 2012 08:07
2 Attachment(s)
If you use Javafoil for instance to generate your airfoil points, you can do the same parameter setup in DM and then just "tick" your chord as parameter (cf figures bellow) after you can just edit them in the WB and everything updates automatically.
VuiYee April 23, 2012 08:12
Thanks you..
VuiYee April 26, 2012 13:27
If i not using javafoil, i using transfer my coordinates from the internet. Any solution to change the chord length?
