[ICEM] A few ideas for blocking in this case? ( tube submerge in cylinder) |
April 30, 2012, 07:49 |
Dustin
Rep Power: 14 |
Hi everyone!
I have a dual fluidized bed project with CFD simulation ( 2D simulation done!). and now is 3D. This is my case ( this tube is downcomer from cyclone) My ICEM files :http://www.mediafire.com/download.php?mtatpynzozwnmie thanks ! |
May 2, 2012, 04:54 |
Andrey
Rep Power: 16 |
Something like this. Сan you attach a geometry file?
May 2, 2012, 06:33 |
Dustin
Rep Power: 14 |
May 2, 2012, 06:53 |
Andrey
Rep Power: 16 |
May 2, 2012, 07:42 |
Dustin
Rep Power: 14 |
I don't understand your mean! It's just a tube ( redirect at the bottom) that discharge material into cyclone. The surface of tube is set as wall when export to Fluent
May 2, 2012, 08:00 |
Dustin
Rep Power: 14 |
May 2, 2012, 08:03 |
Andrey
Rep Power: 16 |
Why then need 3 o-grids for the tube (inside tube)? Just one o-grid.
May 2, 2012, 08:38 |
#9 |
Andrey
Rep Power: 16 |
Like this?
May 3, 2012, 10:35 |
#11 |
Simon Pereira
Rep Power: 47 |
Ralen's first topology is good...
But his second one is not what Far was talking about... Don't split the Ogrid on the outer pipe, split the Ogrid for the inner pipe... Actually, when you first make that inner ogrid, set it up for being a bit larger than the inner pipe (so it is half outside and half inside the pipe)... Then split that Ogrid and project the middle to the pipe... This way you will have aligned layers both inside and outside your inner pipe...
----------------------------------------- Please help guide development at ANSYS by filling in these surveys Public ANSYS ICEM CFD Users Survey This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)... CFD Online Users Survey |
Display Modes | |
ICEM block mesh with a ball in a cylinder tube | Li | CFX | 6 | August 11, 2008 06:44 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 13:24 |
case studies, vortex shedding cylinder | Allan Cross | FLUENT | 2 | May 30, 2005 15:13 |
Turbulent steady flow around a circular cylinder | Mirek Kabacinski | FLUENT | 0 | July 23, 2003 19:40 |
moving cylinder | blur boy | Main CFD Forum | 4 | October 12, 2001 06:32 |
