[ANSYS Meshing] Error: cannot remove all faces from a body |
April 25, 2012, 12:20 |
James Willie
Hi All,
I am new to ansys meshing and i am tryign to mesh a heat exchanger using the Fill option. I select all surfaces and then deselect the outer surfaces. The trobule i am having is with the fins that have a helical shape of thickness of about 0.15mm. I leave them like that (that is without deselecting any of their sufaces since the surfaces on both sides are seeing the the air flow through the channel) in the channel but the fill option to help me extract the fluid volume is not working because of them. Not sure how to work about this problem. Any help or suggestion would be appreciated. Jimmy |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 09:01 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
