A few ideas for blocking in this case? ( tube submerge in cylinder)
Hi everyone!
I have a dual fluidized bed project with CFD simulation ( 2D simulation done!). and now is 3D. This is my case ( this tube is downcomer from cyclone) http://img688.imageshack.us/img688/4664/solidn.png http://img337.imageshack.us/img337/7165/downcomer.png My ICEM files :http://www.mediafire.com/download.php?mtatpynzozwnmie thanks ! |
2 Attachment(s)
Something like this. Сan you attach a geometry file?
Can you attach the block file? p/s: About the full geometry file, Sorry I can't post because this project is confidential:o |
create another o-grid around the pipe to better control the quality.
1 Attachment(s)
3 Attachment(s)
yes, it is. By moving the vertices things will be much better(can be done at latter stages when topology is freezed).
Ralen's first topology is good...
But his second one is not what Far was talking about... Don't split the Ogrid on the outer pipe, split the Ogrid for the inner pipe... Actually, when you first make that inner ogrid, set it up for being a bit larger than the inner pipe (so it is half outside and half inside the pipe)... Then split that Ogrid and project the middle to the pipe... This way you will have aligned layers both inside and outside your inner pipe... |
