[ICEM] A few ideas for blocking in this case? ( tube submerge in cylinder)
Like Tree14Likes
  • 3 Post By Ralen
  • 1 Post By Ralen
  • 2 Post By Far
  • 1 Post By Ralen
  • 1 Post By Ralen
  • 2 Post By Far
  • 4 Post By PSYMN
Old   April 30, 2012, 06:49
Talking A few ideas for blocking in this case? ( tube submerge in cylinder)
Dustin
DungPham is on a distinguished road
Hi everyone!
I have a dual fluidized bed project with CFD simulation ( 2D simulation done!).
and now is 3D. This is my case ( this tube is downcomer from cyclone)
My ICEM files :http://www.mediafire.com/download.php?mtatpynzozwnmie
thanks !
DungPham is offline   Reply With Quote
Old   May 2, 2012, 03:54
Andrey
Ralen is on a distinguished road
Something like this. Сan you attach a geometry file?
Far, PSYMN and DungPham like this.
Ralen is offline   Reply With Quote
Old   May 2, 2012, 05:33
Dustin
Thank you so much!
Can you attach the block file?
p/s: About the full geometry file, Sorry I can't post because this project is confidential
Old   May 2, 2012, 05:53
Andrey
Ok! But I don't understand the geometry of the tube. The tube have 3 independent flows, separated by a thin walls?
DungPham likes this.
Old   May 2, 2012, 06:36
Far
Sijal
create another o-grid around the pipe to better control the quality.
Old   May 2, 2012, 06:42
Dustin
I don't understand your mean! It's just a tube ( redirect at the bottom) that discharge material into cyclone. The surface of tube is set as wall when export to Fluent
Old   May 2, 2012, 07:00
Dustin
You mean o-grid 4 blocks outside of pipe?
Old   May 2, 2012, 07:03
Andrey
Why then need 3 o-grids for the tube (inside tube)? Just one o-grid.
Old   May 2, 2012, 07:38
Andrey
Like this?
Old   May 2, 2012, 12:00
Far
Sijal
yes, it is. By moving the vertices things will be much better(can be done at latter stages when topology is freezed).
Ralen and DungPham like this.
Old   May 3, 2012, 09:35
PSYMN's Avatar
Simon Pereira
Ralen's first topology is good...
But his second one is not what Far was talking about... Don't split the Ogrid on the outer pipe, split the Ogrid for the inner pipe...
Actually, when you first make that inner ogrid, set it up for being a bit larger than the inner pipe (so it is half outside and half inside the pipe)... Then split that Ogrid and project the middle to the pipe...
This way you will have aligned layers both inside and outside your inner pipe...
Far, Ralen, DungPham and 1 others like this.
CFD Online Users Survey
ICEM block mesh with a ball in a cylinder tube Li CFX 6 August 11, 2008 05:44
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
case studies, vortex shedding cylinder Allan Cross FLUENT 2 May 30, 2005 14:13
Turbulent steady flow around a circular cylinder Mirek Kabacinski FLUENT 0 July 23, 2003 18:40
moving cylinder blur boy Main CFD Forum 4 October 12, 2001 05:32
