May 30, 2012, 09:12 |
Domain help...
abishai murday
Rep Power: 15 |
Hi everyone
Could someone help me on this, i have my airfoil and 2 faces round it. The bigger one is the domain and the smaller one is to have better control over the meshing around the airfoil...the only problem im facing is how to use the boolean. I want the inner rectangle to be still connected to the outer one as one whole face while having the aifoil extracted from it....any suggestions?? http://img267.imageshack.us/img267/5743/57055510.png thank you |
May 30, 2012, 09:36 |
Maxime Perelli
Rep Power: 41 |
Are you refering to this thread?
http://www.cfd-online.com/Forums/ans...hing-help.html Let's say you have your big rectangle and your airfoil (already splitted >> hollow) Then split the domain with the edges from small rectangle
In memory of my friend Hervé: CFD engineer & freerider |
May 30, 2012, 12:04 |
abishai murday
Rep Power: 15 |
HI Max
yea its from the thread before...so basically you are telling to first apply the boolean on the airfoil from the inner box then split the inner box from the outer domain... thanks again |
May 31, 2012, 00:41 |
Maxime Perelli
Rep Power: 41 |
I adviced you to split your domain with an ellipse or a circle.
Your rectangle edges won't be at equi-distance from your airfoil.
Domain Imbalance | HMR | CFX | 5 | October 10, 2016 05:57 |
Domain format problem on airfoil flow simulation | andrenonaka | CFX | 14 | December 7, 2015 00:42 |
Vertical Axis Wind Turbine Rotating Domain Problems | TWaung | CFX | 4 | May 1, 2012 03:14 |
CFX domain comparison | Kiat110616 | CFX | 4 | April 3, 2011 22:43 |
CFX Solver Memory Error | mike | CFX | 1 | March 19, 2008 07:22 |
