-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [ANSYS Meshing] How to include an internal surface in fluid vol (http://www.cfd-online.com/Forums/ansys-meshing/101463-how-include-internal-surface-fluid-vol.html)
jwillie2000 May 4, 2012 11:10
Hi All,
I have a case where i have to model a heat exchanger geo. The fins are in a channel and through this channel air is flowing. The air is the fluid that i want to model as it flows through this channel but i want the fins to be included in the fluid simulation with walls boundaries assigned to them. My problem is that when i use the "fill" option i am able to extract the fluid volume and i can also mesh it (both fluid and fins) but when i import it into fluent only the fluid seems to be appearing. The fins or the surfaces defining the fins do not appear. I remember that in ICEM CFD, one can include an internal surface within a fluid volume. Any idea how to work around this problem?
In my DesignModeler, the fins are appearing as "Surface bodies" and the channels as "Solids"
Thanks!
Jimmy
