[GAMBIT] tangent edges and high skewness
Old   May 3, 2012, 22:21
Default tangent edges and high skewness
Caroline Vandame
CaroVandame is on a distinguished road
Hello everyone
I'm trying to mesh a bagless filter which looks like the one on the picture with hexahedral cells only.
At first my inlet was one volume and my "center piece" was another one. However, it creates a very small sliver at the connection, and meshing it leads to high skewness cells.
Here are my questions:
-is there an easy way to select a particular cell and refine it in one direction in Gambit?
-is this one case where using virtual geometries could help? I could create virtual faces that include both my sliver face and my central face, and mesh it easily, however, at the connections planes, how do I match the meshes?
Any idea/tip/... will be greatly appreciated, I'm quite new to Gambit!
Thanks
Caroline
CaroVandame is offline   Reply With Quote
Old   May 3, 2012, 22:25
Caroline Vandame
Or third question: can Fluent directly adapt cells under a certain quality threshold? And can you adapt only in one direction?
Old   May 4, 2012, 00:34
Default Similar, but done in ICEM
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
http://www.youtube.com/watch?v=KabKFrJK3fM
http://www.youtube.com/watch?v=hkHoXMCpfMk
Far is offline   Reply With Quote
Old   May 4, 2012, 01:28
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
can you post a picture with a zoom at your skewed cells
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   May 4, 2012, 09:41
Caroline Vandame
Very interesting video, thanks, but like mAx, I wonder what your skewness is at the tangent point?
It is easy to create the same kind of mesh in Gambit, but the cells at the tangent junction are highly skewed...
Old   May 4, 2012, 15:45
Caroline Vandame
What about tmerge?
The good point is I can define the cylinder slice at the level of the inlet and the inlet as one volume, and I can mesh it easily (the sliver disappears inside the bottom face). However, part of this "merged" bottom face needs to be defined as interior and the other one as wall. I don't know how to do that. Creating virtual faces doesn't help since they don't get exported.
Any input?
Old   May 4, 2012, 19:37
Caroline Vandame
UPDATE: it seems that tmerge is the way to go (or use Fluent's ability to open multiple meshes at once).
Now I have problems with Fluent to create the grid interfaces, so I'll open a new thread in the right forum!
Thanks everyone
Old   May 7, 2012, 02:11
Far
Sijal
For grid interfaces (in gambit), you should search the older posts by -mAx-, where he has explained very nicely that how to decouple two volumes and create the interfaces.
AND/OR
If you can send geometry privately or attach on forum, then I can make the mesh for your in ICEM CFD.
Old   May 7, 2012, 09:39
Caroline Vandame
Thanks Far, but I think I figured it out!
Like you said, mAx posts were quite useful.
Here is the new thread if someone is interested.
http://www.cfd-online.com/Forums/flu...tml#post359498
limit high velocity values riesotto OpenFOAM 7 July 25, 2016 14:28
Importing CAD geometry and Editing edges to match Ahmed CFX 15 March 21, 2016 12:39
Gambit mesh: tangent edges and high skewness CaroVandame FLUENT 2 May 3, 2012 22:21
Boundary layer meshing with sharp trailing edges Andrew Berner FLUENT 1 August 28, 2007 17:39
high aspect ratio elements Olivier CFX 5 April 3, 2003 06:55
