[Other] Swept Tapered Wing
Old   May 10, 2012, 06:40
Default Swept Tapered Wing
Stephen
moonser is on a distinguished road
Hi guys I know that this is probably a basic question but I am massively struggling here.
I have to create a swept tapered wing in Ansys. I have the 2 airfoils coordinates and generated them in the geometry. I CANNOT seem to join them.
Could anyone shed some light on how I can do this to create a 3-D wing. Any input would be greatly appreciated.
moonser is offline   Reply With Quote
Old   August 17, 2012, 15:35
brijeshdubey11's Avatar
brijesh dubey
brijeshdubey11 is on a distinguished road
yes you can create a swept wing. just import the co-ord data and by transforming the tip airfoil in the x direction as well as in z dirctn you can see your sweep profile. then join the leading edge and trailing edge points and after that you can create surface.this way you can create swept wing.
brijeshdubey11 is offline   Reply With Quote
Forward swept wing simulation abid Siemens 1 June 16, 2012 13:26
Swept tapered wing moonser CFX 1 May 10, 2012 06:37
Determing the flowfield on a swept wing jd88 Main CFD Forum 0 August 26, 2010 14:29
[ICEM] Problems about meshing the swept wing with cylinder end cap kepeng ANSYS Meshing & Geometry 3 June 15, 2010 05:21
How to mesh a swept wing in ICEM? kepeng ANSYS Meshing & Geometry 0 April 24, 2010 12:34
