August 23, 2015, 12:06 |
#21 |
Chris Bennett
Rep Power: 14 |
As above. Mesher will use a different core for each part. If you only have one part you could tell it to use 3 or 30 cores there would be no difference to speed
August 23, 2015, 12:11 |
#22 |
Joe
Rep Power: 14 |
Chris,
Thank you for the reply, I have 2 parts and more than 1000 bodies. I guess this feature works when the software generates the mesh once...I am trying to mesh section by section and see how it goes in each section....In this case, parallel doe snot work. Am I right or I am missing something? Thank you! |
August 23, 2015, 12:51 |
#23 |
Chris Bennett
Rep Power: 14 |
You are right.
I would guess its a lot to do with how the parallel algorithm can split up the tasks. It can treat each part as a separate job in its own right but cannot efficiently cut up a single section to run in parallel If you are meshing something with multiple parts the speed up is wonderful, but that doesn't happen that often. |
October 15, 2015, 11:13 |
#24 |
Rep Power: 15 |
Parallel meshing in ANSYS Meshing works across Parts. If you have a CFD Model with multiple bodies, it will utilize 1 core. If you have multiple parts with non conformals then you can leverage all of your cores
October 15, 2015, 11:54 |
#25 |
Sarang Dalne
Rep Power: 15 |
Hello All,
ANSYS WorkBench Meshing supports parallel meshing of multiple parts. So if you have single multi-body part, then it will mesh that part serially. One reason for that is that they have to maintain conformal mesh between bodies belonging to same part. If you have multiple parts then you are in luck and can utilize all the power of parallel meshing. But remember, parallel meshing is as fast as the slowest meshing part. By default the parallel meshing is on in WB meshing and set to "program controlled" which means that program decides how many cores to use. Regards, Sarang |
Display Modes | |
[snappyHexMesh] Parallel meshing with OP 2.0.0 | Aurelien Thinat | OpenFOAM Meshing & Mesh Conversion | 34 | March 27, 2012 19:55 |
Parallel Meshing in ANSYS 13 | makkks | ANSYS Meshing & Geometry | 1 | September 5, 2011 13:34 |
Parallel meshing + simulating. need Help | nicolarre | OpenFOAM | 2 | April 11, 2011 12:04 |
Parallel meshing using XP64 with PVM in CFX Mesh | Huw | ANSYS Meshing & Geometry | 4 | July 12, 2010 11:24 |
CFX5.6 (Build) Parallel Meshing | David Hargreaves | CFX | 2 | January 12, 2005 13:39 |
