[ANSYS Meshing] Meshing in parallel
Like Tree1Likes
Old   May 11, 2012, 09:02
Default Meshing in parallel
Helen
oborona is on a distinguished road
Hi!
Can I launch Ansys Meshing in the parallel mode?
oborona is offline   Reply With Quote
Old   May 11, 2012, 09:26
Far
Sijal
http://www.cfd-online.com/Forums/ans...nsys-13-a.html
Old   May 11, 2012, 09:34
Helen
Thanks. I already have read this thread. But I don't understand how to launch Ansys Meshing in parallel.
I know that in Fluent or in ICEM I can specify the number of the processors. Can I do this launching Workbench and working in Ansys Meshing?
Old   May 11, 2012, 09:39
Far
Sijal
I guess this might be the solution to your problem
workbench : Tools >>> options >>> Mechanical APDL . Here you can specify the No of processor and / or GPU support.
Old   May 11, 2012, 09:42
Default This is the solution
Far
Sijal
In ansys meshing go to tools >>> options >>>common settings >>> Parallel processing.
Old   May 11, 2012, 09:45
Helen
Thank you very much!!! I have found it!!!
Old   June 3, 2012, 04:54
Seran Reschim
ch_ohm is on a distinguished road
I already set follow your comment but Ansys meshing still use only 1 cpu. Please advise me more
ch_ohm is offline   Reply With Quote
Old   June 3, 2012, 05:08
Far
Sijal
It should work. some snapshots will definitely help to identify problem.
Old   June 13, 2012, 00:38
Seran Reschim
I mean I set in >>tools >>> options >>>common settings >>> Parallel processing. I set 11 core but in the " Task manager" still show cpu usage is 1 So please let me know how to make it happen. thank
Old   June 15, 2012, 05:20
RoJ
Rikard Johanssson
RoJ is on a distinguished road
Parallell meshing will come with v15 and a beta release in v14.5
RoJ is offline   Reply With Quote
Old   June 15, 2012, 09:03
Seran Reschim
Really ? I think the current version is 14. So, could you please let's me know about how long about that version will release ? thank you
Old   June 15, 2012, 15:59
RoJ
Rikard Johanssson
This is just what I have heard. My guess is that v 14.5 comes in August or in September. I am looking forward to the parallell functionality !
Old   June 18, 2012, 11:12
Seran Reschim
Thank you very much
Old   November 15, 2013, 16:34
Benjamin Stanke
xtphgu is on a distinguished road
Hi I am using Ansys 14.5.7 and i have the same problem like ch_ohm. Set up to parallel but still meshing in sigle mode... What's the use for the parallel settings? Is there no chance to mesh parallel now with 14.5.7?
xtphgu is offline   Reply With Quote
Old   January 22, 2014, 07:25
Smile Parallel Meshing
  #15
Lamboram
lamboram is on a distinguished road
Hello all,
Parallel meshing has been a new feature in Ansys 15. It was not available before. Now one can assign particular no. of cores in meshing a model. the requirement is minimum 2 Gigs of RAM per core. so if you have a 4 core processor, you would need minimum 8 Gigs of RAM.
It has been reported that already Ansys 15.0 meshing is around 3-4 times faster (of course depends on model and method). but it is definetly faster than the previous versions.
cheers,
Lamboram
P.S: You dont need HPC license to access this feature
lamboram is offline   Reply With Quote
Old   January 29, 2014, 10:38
Chris Bennett
dr.chris is on a distinguished road
Parallel meshing in v15 is on by default and has been said is unconnected with HPC packs. It takes the form of assigning different parts to different processors, so may not show any extra improvement if you only have one part!.
It is definitely worth while making sure that the number of processors active is less than the number you have on your machine, if you want to use it for anything else at the same time as you mesh.
The new changes in the mesher are really very impressive though
Far likes this.
dr.chris is offline   Reply With Quote
Old   February 20, 2014, 00:50
Default Ansys 15 Parallel Meshing??
  #17
Rob Muggleton
robmuggleton is on a distinguished road
Has anyone got this to work? I have specified the number of processors in ICEM 15 and from the workbench in mechanical APDL and from within the meshing modeler. But it still only uses about 14% of my CPU........
robmuggleton is offline   Reply With Quote
Old   February 20, 2014, 01:14
Default gpu acceleration
  #18
Rob Muggleton
I can get gpu acceleration working though i think
Old   March 2, 2015, 15:09
Pavel
powpawell is on a distinguished road
Parallel meshing in v15.0 works for more parts. If your model is only one part, it won't run. At least it did not work for me (it used only one core). You can split the model in different parts and it will work
Hope this helps a bit
powpawell is offline   Reply With Quote
Old   August 22, 2015, 13:42
Joe
enayath is on a distinguished road
Hello Folks,
I am trying to use Ansys meshing 15.07 for the physical preference of CFD. I set number of CPUs for parallel meshing to 11. My machine has 30 cores but it does not seems Ansys uses more than 1.(task manager)
Any idea would be appreciated!
enayath is offline   Reply With Quote
[snappyHexMesh] Parallel meshing with OP 2.0.0 Aurelien Thinat OpenFOAM Meshing & Mesh Conversion 34 March 27, 2012 18:55
Parallel Meshing in ANSYS 13 makkks ANSYS Meshing & Geometry 1 September 5, 2011 12:34
Parallel meshing + simulating. need Help nicolarre OpenFOAM 2 April 11, 2011 11:04
Parallel meshing using XP64 with PVM in CFX Mesh Huw ANSYS Meshing & Geometry 4 July 12, 2010 10:24
CFX5.6 (Build) Parallel Meshing David Hargreaves CFX 2 January 12, 2005 12:39
