Home > Forums > ANSYS Meshing & Geometry
[ANSYS Meshing] Applying boundary conditions on holes
Old   May 12, 2012, 19:41
Default Applying boundary conditions on holes
Adil Syyed
adilsyyed is on a distinguished road
Boundary conditions are applied on named selections in ANSYS CFX as stated in the tutorials.
But do we always need a surface for this named selection?
Let say I have an inlet pipe, so do I have to make a surface to close the end of the pipe, ( that surface will be used for named selection)?
Or the pipe too is a solid rather than tube?
adilsyyed is offline   Reply With Quote
Old   May 12, 2012, 23:25
Gweher's Avatar
Gwenael H.
Gweher is on a distinguished road
Well for your pipe, if you want to simulate the flow inside then you need a volume mesh, so you will be able to select the inlet and outlet surface of your pipe, so your pipe will be “closed” with a surface that you will be able to select.
The name selection is not a mandatory procedure, but it’s easier once you need to setup your boundary conditions in CFX. You can still, within CFX create BC, but if you model more complex geometries with several inlets/outlets you will gain time by creating named selections before.
Gweher is offline   Reply With Quote
Old   May 13, 2012, 04:28
Adil Syyed
Thank you for the help. I really was confused about this thing.
Thread Tools
Trackbacks are On
Implementation of boundary conditions for FVM Tom Main CFD Forum 7 August 26, 2014 05:58
Proper Pressure Boundary Conditions for Buoyant Flow mchurchf OpenFOAM 0 March 25, 2010 13:16
Update boundary conditions calculated by an external program CedricVH OpenFOAM 2 January 15, 2010 12:55
Boundary conditions? Tom Main CFD Forum 0 November 5, 2002 02:54
