[ICEM] Import a Nastran file into ICEM CFD
Old   May 14, 2012, 07:37
Default Import a Nastran file into ICEM CFD
Norger
norger is on a distinguished road
Hey,
I am desperate about importing a Nastran file into ICEM CFD.
The Nastran file only has the volume elements (no surfaces and shell elements).
There are a lot of mistakes:
1) The Mesh in the Nastran file has some parts with hexagonal elements and they aren`t allowed in FLUENT. When I change them into tetra elements (Edit Mesh -> Convert Mesh Type -> All Types to Tetra), there occurs a problem when transforming the mesh into a mesh-file .msh
--> Error : face (near node 7558) is attached to more than 2 cells.
This face isnīt the only one with the mistake (> 100).
How can I solve the problem?
2) When I delete all parts with hexagonal elements, I can transform the mesh into a msh.file but I canīt import it into fluent
--> Error: Build Grid: Aborted due to critical error.
Did anyone has the same problem or do you know how to solve it? Is there a way to create surfaces from the volume elements and import it into icem cfd as a .igs or .stp that I can create my own mesh?
Thank you very much in advance!
Best Greetings
norger is offline   Reply With Quote
icem cfd, import mesh, nastran
GPU Linear Solvers for OpenFOAM gocarts OpenFOAM Announcements from Other Sources 37 August 17, 2022 14:22
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 06:29
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 09:50
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
PHI file structure Eugene Phoenics 9 November 2, 2001 22:00
