[ICEM] Splitting Edge (airfoil meshing)
Like Tree5Likes
  • 3 Post By PSYMN
  • 2 Post By Ananthakrishnan
Old   May 15, 2012, 13:31
Default Splitting Edge (airfoil meshing)
James Hetfield is on a distinguished road
Hello everybody
I've got a problem with "Split Edge" in ICEM 14
based on the tutorial provided by Simon (3 parts) I can do the Edit Edge-->Split Edge for those two edges inside the airfoil so they will be projected on the airfoil curves. (I've attached the picture after doing this)
but I wanna do a smoother Split. I mean as you can see in the figure, there are sharp facets that I want do a better job with splitting edges to get rid of them and have a smoother edges. (because theses facets are killers for drag coefficient calculation)
does anyone know how to do Splitting Edge smoother?
James Hetfield is offline   Reply With Quote
Old   May 15, 2012, 14:17
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Well CFD by nature is not smooth. That's why we call it dicretized solution as compared to exact solution.
split edge has nothing to do with smoothness. It all related to basic CFD
Far is offline   Reply With Quote
Old   May 15, 2012, 14:26
I know that, but these facets that are approximating the airfoil surface should be smoother than this (they should be shorter lines so they can be put on the airfoil surface more precisely)
if you dont do that, the nature of flow will be changed too much and will change the drag and lift coefficients
Old   May 16, 2012, 09:11
Default Solutions...
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Yes, there are at least a couple of ways you can solve the problem...
1) Yes, ICEM CFD does usually facetize the geometry to make display and projection quicker. You can control this with "Settings => Model => Triangulation" Change it from 0.001 to 0.0000001 and see how that looks.
2) But you don't need to have the mesh project to the facets, you can project to the actual bspline geometry. This setting is used in high end turbo applications for exactly this reason that James is concerned about. To do that, go to "Settings => Meshing options => Hexa/Mixed => Project to Bsplines...
Best regards,
Simon
Far, James Hetfield and metmet like this.
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   May 16, 2012, 09:14
Thumbs up
Far
Sijal
I didn't know that. But in this way we are looking for accuracy at micron level, which may not be possible in actual geometry. isn't it?
Old   May 16, 2012, 09:17
PSYMN's Avatar
Simon Pereira
The Bspline geometry is mathematically precise... (well beyond the micron level), but you actually don't get any better than your final mesh resolution (since you are using linear elements).
Old   May 16, 2012, 12:56
Simon, I really dont know how to thank you
THANKS A LOT
Old   May 16, 2012, 12:57
Far, thank you too for responding to my posts all the time and helping me
really appreciate it
Old   May 16, 2012, 14:08
I have another question Simon
when I follow your tutorial, when I wanna do the Automatic Linear Split Edge, sometimes it does not work and sometimes works
what is the problem?
Old   May 16, 2012, 14:31
Best regards,
Simon
OK, I set these options
now, what should I do? the same procedure as explained in the tutorial (Edit Edge--> Automatic Linear?) ?
besides, sometimes Automatic Linear doesnt work for me and I dont know why
Old   May 16, 2012, 18:00
Ananthakrishnan.A.S
Ananthakrishnan is on a distinguished road
Send a message via Skype™ to Ananthakrishnan
A common mistake would be to use automatic linear without applying any nodes on the edges..In that case ICEm will be projecting the two points of the edge(default number of nodes) on to the curves..Try updating the edge parameters and then using the auto linear option..
This is what happened to me..
PSYMN and FJSJ like this.
Ananthakrishnan is offline   Reply With Quote
Old   May 16, 2012, 19:30
Another question:
when I generate the grid, the lines that go off the wall (airfoil surface) are not normal to it (even after smoothing)
I have attached the picture near to the surface
Am I doing something wrong???
what options should I use while smoothing? (Grid Expansion or others....???)
Old   May 17, 2012, 12:24
PSYMN's Avatar
Simon Pereira
Ananthakrishnan was right about the automatic linear...
Orthogonality is what you are looking for in your latest querry.
The hexahedral smoother can improve orthogonality, but you can also improve it with better edge/vertex locations or shapes or improving the match between distributions on opposite sides of the body.
Some times, there isn't much you can do about it except relax and be glad that most solvers can handle it.
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[ICEM] Meshing sharp edge (no airfoil) jrunsten ANSYS Meshing & Geometry 14 April 24, 2012 04:49
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
Poor Residuals at Intersection Between Symmetry Plane and Airfoil Leading Edge TWaung CFX 2 February 16, 2010 08:11
