Home > Forums > ANSYS Meshing & Geometry
[GAMBIT] Problem sweep 2D airfoil to 3D
Old   May 18, 2012, 03:58
Default Problem sweep 2D airfoil to 3D
nerbur is on a distinguished road
Hi all,
I am trying to create a 3d airfoil from a 2D mesh.
For do this I use "sweep face" tool. As you can see in next image, the volume is created correctly in first and last face, but when Gambit try to sweep the intermediate face appears the next error.
ERROR: The faces are not coincident
Please try disconnecting the face being swept from upper topology
I'm also tried to copy and translate the mesh and then create the wireframe, but still giving error with face that contains the foil when I try to create the voulme.
I tried to do this operation splitting the middle face but ever I have a one face that can't be extruded.
Greetings
nerbur is offline   Reply With Quote
Old   May 18, 2012, 04:42
Far
Sijal
Far will become famous soon enoughFar will become famous soon enough
Send a message via Skype™ to Far
are you trying to sweep all faces at the same time? from error, I can infer that you are sweeping side faces first and then the inner surface with airfoil?
Far is offline   Reply With Quote
Old   May 18, 2012, 05:23
Yes, I sweep the three faces at same time but only first and last extrude.
If I try to sweep interdependently the result is the same.
Indeed, I try to do a mesh with only one face, but I ever have an error when try to sweep a mesh that contains the airfoil.
Old   May 21, 2012, 01:52
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
did you try to sweep the faces in volume from middle first?
If it failed, try to merge the surface with airfoil with the disk, and retry to sweep.
Sweep both volumes at extremities once the one in the middle is successfull
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Thread Tools
Trackbacks are On
Problem Meshing Airfoil erodv OpenFOAM 12 January 11, 2012 18:46
Problem With Importing Coordinates for an Airfoil Amerikaneca ANSYS Meshing & Geometry 3 July 8, 2011 07:28
Handling cyclic BC from gambit to openfoam for a cascade airfoil problem - OF 1.6 maverick OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... 2 June 18, 2011 04:36
Problem with boundary condictions in an airfoil bego OpenFOAM Running, Solving & CFD 0 September 22, 2010 05:56
Sweep Real Faces, Time Problem !!! Thomas Farmakis & George Zioupos FLUENT 0 June 8, 2001 07:54
