Home > Forums > ANSYS Meshing & Geometry
[ICEM] Scripting error "tdv_pos(v.view)"
Like Tree2Likes
  • 2 Post By inros
Old   May 21, 2012, 08:24
Default Scripting error "tdv_pos(v.view)"
Sören
despaired student is on a distinguished road
During scripting I received this error:
can't read "tdv_pos(.v.view)": no such variable
while executing
Does someone know what this particular variable is good for and where I can find it? Is this a ICEM-error or not? Where would you suggest to start searching for the mistake?
kind regards
despaired student is offline   Reply With Quote
Old   May 21, 2012, 10:55
Sören
...I just tried the replay-script via replay-control in ICEM. There it's working but when I use it as a batch job: icemcfd -batch script2.rpl
the error occurs.
System: Linux-RedHat
Old   October 3, 2013, 08:58
Ines Rosinha
inros is on a distinguished road
Hi.
I know this post is old but I have had the same error occurring while running icem in batch mode and I found a solution that work on my project.
Since I didn't find an answer online, I think it is useful to share the solution because there are most likely other people with same problem.
I have previously written the following in the batch file:
"C:\Program Files\...\icemcfd.bat" -batch "C:\Users\inros\...\Mesh.rpl"
I have solved it by adding -script in the code:
"C:\Program Files\...\icemcfd.bat" -batch -script "C:\Users\inros\...\Mesh.rpl"
Best regards.
Lance and aek16 like this.
inros is offline   Reply With Quote
Old   November 6, 2014, 05:31
Luke
aerospace84 is on a distinguished road
i can only say thanks to you, to have post the solution once you have solved the problem, without leaving the post without answer.
So thank you!
aerospace84 is offline   Reply With Quote
Old   June 7, 2016, 05:24
aek16 is on a distinguished road
Thank you. That works totally
Again thank you
aek16 is offline   Reply With Quote
Thread Tools
Trackbacks are On
python scripting in WB Windows.Forms OpenFileDialog() crashing mvoss CFX 0 November 4, 2011 04:46
ICEM CFD Scripting Prakash.Paudel ANSYS Meshing & Geometry 2 August 17, 2011 15:53
CFD GEOM scripting sriharish28 Main CFD Forum 0 January 19, 2010 05:06
ParaFoam Scripting iyer_arvind OpenFOAM Paraview & paraFoam 7 November 2, 2006 05:06
ALGOR? Its scripting language? Compare to Fluent? Chris Bailey Main CFD Forum 2 November 16, 2005 17:58
