May 21, 2012, 08:24 |
Scripting error "tdv_pos(v.view)"
Sören
During scripting I received this error:
can't read "tdv_pos(.v.view)": no such variable while executing Does someone know what this particular variable is good for and where I can find it? Is this a ICEM-error or not? Where would you suggest to start searching for the mistake? kind regards |
May 21, 2012, 10:55 |
Sören
...I just tried the replay-script via replay-control in ICEM. There it's working but when I use it as a batch job: icemcfd -batch script2.rpl
the error occurs. System: Linux-RedHat |
October 3, 2013, 08:58 |
Ines Rosinha
Hi.
I know this post is old but I have had the same error occurring while running icem in batch mode and I found a solution that work on my project. Since I didn't find an answer online, I think it is useful to share the solution because there are most likely other people with same problem. I have previously written the following in the batch file: "C:\Program Files\...\icemcfd.bat" -batch "C:\Users\inros\...\Mesh.rpl" I have solved it by adding -script in the code: "C:\Program Files\...\icemcfd.bat" -batch -script "C:\Users\inros\...\Mesh.rpl" Best regards. |
November 6, 2014, 04:31 |
Luke
i can only say thanks to you, to have post the solution once you have solved the problem, without leaving the post without answer.
So thank you! |
June 7, 2016, 05:24 |
Rep Power: 10 |
Thank you. That works totally
Again thank you |
python scripting in WB Windows.Forms OpenFileDialog() crashing | mvoss | CFX | 0 | November 4, 2011 03:46 |
ICEM CFD Scripting | Prakash.Paudel | ANSYS Meshing & Geometry | 2 | August 17, 2011 15:53 |
CFD GEOM scripting | sriharish28 | Main CFD Forum | 0 | January 19, 2010 04:06 |
[OpenFOAM] ParaFoam Scripting | iyer_arvind | ParaView | 7 | November 2, 2006 04:06 |
ALGOR? Its scripting language? Compare to Fluent? | Chris Bailey | Main CFD Forum | 2 | November 16, 2005 16:58 |
