[ANSYS Meshing] Why doesn't ANSYS Meshing allow me to make a very fine mesh? |
May 21, 2012, 11:04 |
Ali
I'm trying to make a C-mesh over an airfoil.
The first image shows my original mesh. But when I try to increase the bias factor or the number of divisions, so as to improve the resolution near the airfoil, I get the second image. Any idea why this is happening? Last edited by ali.qasim; May 21, 2012 at 11:07. Reason: attached images |
May 22, 2012, 03:50 |
For mapped face to work, you have to increase the bias/number of divisions on all Edge sizing functions. U've probably been following the Cornell airfoil in WB tutorial, so, just increase the number of divisions on the left part too (C grid) so it'll have the same number of divisions as the wake part on the right.
May 25, 2012, 19:11 |
Inflation
Ricardo
Hi ali.qasim,
By doing what our friend said about increasing the number of elements probably you will find a solution for the related problem. Have you tried to built some inflation layers on this aerodynamic profile? I am trying to do this, but I cant find a solution. Thanks, Ricardo |
May 26, 2012, 04:48 |
Ali
scipy: Thanks. That did work up to an extent, but the problem came up again when I wanted more biasing. I guess I'll have to just start learning ICEM-CFD.
ricardo: I haven't tried inflation layers. Will do so and let you know if the problem is solved. |
May 26, 2012, 06:04 |
Ali
Just realized inflation won't work as the domain is divided into four faces around the airfoil.
bias factor, fine, mesh |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 | flakid | OpenFOAM Installation | 16 | December 28, 2010 08:48 |
ANSYS Meshing - DC Mesh Quality | alven299 | ANSYS Meshing & Geometry | 5 | July 19, 2010 11:34 |
[Commercial meshers] How to make a good Low-Re Mesh ? | Gearb0x | OpenFOAM Meshing & Mesh Conversion | 0 | February 12, 2010 04:48 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
