[GAMBIT] Problem with merging edges/faces
Old   June 11, 2012, 11:49
Default Problem with merging edges/faces
Bahar
bahar is on a distinguished road
Hello everybody,
I have a problem while importing geometry from Solid Works to Gambit.
As showed in figures, there are 3 blades that would be meshed. But every side edges of blades has broken in two edges while there are circles in leading edge and trailing edges.
So when I mesh the airfoil it wouldn't get a smooth mesh because of difference in scale of edges. I tried to merge them but while the geometry is complex, it could not create a real face/edge.
Is there any idea to resolve this problem?
Thank you in advance,
bahar
bahar is offline   Reply With Quote
Old   June 12, 2012, 01:36
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
can you provide the dbs file?
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   June 12, 2012, 02:44
-mAx-'s Avatar
Maxime Perelli
Ok I checked your dbs file, and your problem, can be resolved by using the cleaning tool (use clean short edges: first on the left) it will collapse the trailing edge.
But you have other problems:
you need to connect faces 27 and 47
and you also have problem with surfaces 40 and 28: For that delete volume up, and reconstruct it with remaining surfaces (sticht faces)
Old   June 12, 2012, 03:01
Default Re:problem with importing geometry in Gambit
Bahar
Wow! Thank you so much for all this helpful points
If I understand correctly, you mean by deleting short edges I can merging the faces. Isn't it?
And about connecting faces 47 & 27, do you mean defining an interface between them in Zone section(green cube)?
And problem with surfaces 40 and 28, the cylindrical faces should be moving but the frustums are stationary. I thought they would be separate volumes, what's wrong?
Regards
Bahar
Old   June 12, 2012, 03:08
-mAx-'s Avatar
Maxime Perelli
make first a good mesh for steady. Then adapt your mesh for moving mesh.
-For deleting short edges, use cleaning tool: click on update (short edge), and click on auto.
Gambit will automatically collapse trailing edges
-For faces 47 and 27, just connect them (forced virtual)
-For 40 and 28, as I said below, generate a mesh for steady state first (so delete the volume, and reconstruct it)
Once your mesh is ok, compute, check if flowfield is ok, then work on the motion
Old   June 12, 2012, 03:16
Bahar
Thank you dear mAx!
I'll do all this and will announce you about the result. But there is a problem, I'm using Gambit version 2.3, I can not find here what you said about cleaning tool unfortunately.
Regards,
Bahar
Old   June 12, 2012, 03:26
-mAx-'s Avatar
Maxime Perelli
I checked and Cleaning Tool was already available at release 2.1.
You can find it in Tools/Geometry Clean-Up
http://cdlab2.fluid.tuwien.ac.at/LEH...ide/mg0504.htm
Old   June 12, 2012, 03:33
Bahar
Oh,yes! I just found it
I should use the first item (clean up short edge), right?
Thank you very much dear mAx!
Regards,
Bahar
Old   June 12, 2012, 03:34
-mAx-'s Avatar
Maxime Perelli
yes
update>auto
Old   June 12, 2012, 03:36
Bahar
OK, thank you in advance!
Regards,
Bahar
Old   June 12, 2012, 03:51
  #11
Bahar
Dear mAx,
I do it as you said, but after cleaning up I lose 3 primary edges of airfoils(button airfoils)!
What's wrong?
Regards
Bahar
Old   June 12, 2012, 04:09
  #12
Bahar
I did it on a new file and it worked correctly!
Thanks for your help mAx
Regards,
Bahar
Old   June 12, 2012, 09:14
  #13
Bahar
Hi dear mAx,
I tried it out and there is a similar problem that Gambit couldn't convert virtual volume/face/edge of blades to real.
What should I do?
Regards,
Bahar
Old   June 13, 2012, 01:03
-mAx-'s Avatar
Maxime Perelli
you should use the cleaning tool, only when your topology decomposition is ready (I mean jjsut befor you start to mesh your model)
Indeed the cleaning tool, will give you finally a virtual entity and it is then no more possible to get a real entity (what you experienced)
Why do you want real entities?
Old   June 13, 2012, 01:19
Default Re
  #15
Bahar
Hi dear mAx,
I should subtract volumes to get appropriate domain as you saw. It it possible subtracting a virtual volume from a real one? And may it cause any problem in Fluent (virtual blades)?
Regards,
Bahar
Old   June 13, 2012, 01:21
-mAx-'s Avatar
Maxime Perelli
no
that's why you need to keep real entities as late as you can, else you cannot handle boolean operations anymore (they are only available for real topologies)
Old   June 13, 2012, 01:30
Default Re
  #17
Bahar
OK, Thank you in advance!
I'll do that.
Regards,
Bahar
Old   June 13, 2012, 04:04
Default Re
  #18
Bahar
Hi dear mAx,
During meshing a discontinuity occurs as showed in figure. It seems that it is as a result of existence of two virtual and aslo two real edge in a face, isn't?
What should i do?
Regards,
Bahar
Old   June 13, 2012, 04:38
-mAx-'s Avatar
Maxime Perelli
in the display options, make all volumes invisible, and display only blades.
Enable shaded modus, and check if the surfaces is ok (where you get degenerated cells)
Old   June 14, 2012, 02:44
Default Re
  #20
Bahar
Hi dear mAx,
I checked the blades as you said and found out a problem in my Solid Works model.
Now, I'm going to improve it and then try it again in Gambit.
Regards,
Bahar
conduction problem venkataramana OpenFOAM 3 December 1, 2013 07:30
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
ICEM mesh merging problem Serge CFX 2 October 22, 2007 06:13
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
