January 16, 2012, 09:03 |
Problems with O-grid
Rep Power: 15 |
Dear all,
I have two questions concerning the O-grid generation which are quite stupid questions, but I wasn’t able to find the answer at the "Help Topics" or anywhere else:
Thanks a million in advance, Lilly |
January 17, 2012, 12:01 |
hi
Hi
answer to your first question you cant see the intermediate faces when your trying to select. The logic is when you select inlet and outlet faces the intermediate faces also get selected automatically. I mean it makes through operation. Still if u want to select the intermediate faces just go near to the face and select it. Its get selected even though u cant see that face. But u can see after selecting. it appears in blue. Answer to your second question just go the merge vertices option and turn on propagate merge option. then merge using two vertices. The entire o grid will be merged. |
January 17, 2012, 17:35 |
Simon Pereira
Rep Power: 47 |
Selecting a face simply allows the ogrid to pass into the next block. You can't see it, but when you selected the face on the INLET, it really also selected the adjacent VORFN block and allowed the OGRID to pass into that dormant block.
There is no need to select a face between two blocks that you can see. Just select the adjacent block and you have the same affect. You can not terminate an Ogrid in a volume, it must be able to "turn around" or you would leave hanging nodes. For your second issue, Kiran is right. Merge Verts with "Propagate" will collapse the Ogrid index away so you can recreate it. You could also use "Reset Ogrid Orthogonality" under "Blocking (tab) => Edit Blocks".
----------------------------------------- Please help guide development at ANSYS by filling in these surveys Public ANSYS ICEM CFD Users Survey This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)... CFD Online Users Survey |
January 18, 2012, 05:59 |
O-Grid Offset
Rep Power: 15 |
Thanks to both of you!
Your advices are working fine! But I got another Problem concerning the O-grid now: Is there any way to scale the O-gird in relation to the size of the single blocks (or edge lengths)? I am asking since my geometry is pretty complex: there are narrowings and the diameter of the inlet is much larger than the diameter of the outlets. Therefore my O-grid looks either at the inlet or at one outlet acceptable depending on the "Offset" (see pics). I tried both changing the "Offset" at the creation and at the rescaling of the O-grid. Thanks a lot for your ideas and help in advance! Lilly |
May 22, 2012, 10:04 |
Simon Pereira
Rep Power: 47 |
Sorry I am so behind in my emails... But I thought I would answer this one anyway...
Yes, you can use "rescale Ogrid". Adjust your index control to only see the half of the model that needs adjusting and then rescale the Ogrid. It will leave the other part alone and the ogrid height will change linearly between. You can also manually adjust edge length to tweak things more precisely.
May 24, 2012, 09:35 |
Christa
Rep Power: 15 |
I have an O-grid problem too. Even though I want to split the blocks inward, in some parts of my geometry the O-grid is created around the blocks, messing everything else up. I have had this before, and I just had to re-adjust the vertices because apparently some angle was not quite right, but I tried that now and it's not working. The geometry is roughly a bent tube, a type that I have meshed several times before using the same method of placing several blocks to follow the curvature. If I learn what may be causing this problem I should be able to work out a solution. Many thanks, Christa |
May 24, 2012, 09:43 |
Ghazlani M. Ali
Rep Power: 28 |
The way i generate O-GRID: split block -> OGRID , then you can select if you want your ogrid around your block or not and define an offset for it.
If your ogrid happens to not be the result you wanted you can modify it in edit block -> modify ogrid. |
May 24, 2012, 09:48 |
Christa
Rep Power: 15 |
Thanks, Ali.
I don't want my O-grid around the blocks and I specify that I want it so. Out of the around 50 blocks that I am using, I get the unwanted O-grid around the block for about 3 of them. I tried moving the O-grid vertices inwards, but the resulting mesh is horrible anyway. It' some kind of bad setup or glitch, and changing the original settings (namely the offset), does not alter the direction of the O-grid, just the size of it. |
Questions for a species transport problems (snapshots attached) | aleisia | FLUENT | 2 | October 9, 2011 04:40 |
grid on a circle | HaKu | Main CFD Forum | 4 | April 15, 2010 11:56 |
MapFields to New Grid For Extreme Grid Deformations due to Body Motion | albcem | OpenFOAM | 0 | May 5, 2009 14:17 |
"grid points" or "grid interface" | ztdep | Main CFD Forum | 1 | June 6, 2007 15:00 |
Problems in grid generation in ICEM | Tim | CFX | 1 | September 30, 2006 06:43 |
