[ANSYS Meshing] How to improve a simple mesh with a negative volume
Old   May 31, 2012, 11:18
Default How to improve a simple mesh with a negative volume
Jan
canev.civelek is on a distinguished road
Hi there,
I was wondering what options i have on improving the mesh. I seem to be giving a negative volume. (4.3e-4).
This seems pretty large. Ive altered the mesh a number of times however this figure is still relativly low. Ive also tried creating the geometry from scratch but no luck.
I have tried mesh/repair-improve/repair and various others in the text command however do not get any change with the volume.
Please let me know what i can do to improve the mesh or sources to find out how todo this.
Thanks again for your help.
canev.civelek is offline   Reply With Quote
Old   May 31, 2012, 12:08
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
One way I do it, i start by a coarse mesh then i refine gradually. i often get them when i set a very small spacing in the edge parameter and i don't know why. I then go back to icem and set a bigger spacing. can we take a look at your mesh ?
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   May 31, 2012, 12:32
Smile
Jan
Hi there,
Ive attached a copy of my mesh, also of a courser mesh which i also tried.
Although it was better (2.5e-3) this is stll pretty poor.
I may even need a finer mesh then the fine one attached to provide the end results i require.
Please let me know what i can do to improve it.
Thanks so much for your help.
By the way im using ANSYS meshing 13.0.
Old   May 31, 2012, 12:36
diamondx's Avatar
Ghazlani M. Ali
they look pretty good. would you mind sending the msh file. or the geometry file ?
Regards,
Ali
Old   May 31, 2012, 12:51
Jan
Sure.
Here is the geometry file
If you send me your email i can send you the whole fine.
Im not sure how to send the .msh file.?
Old   May 31, 2012, 13:09
diamondx's Avatar
Ghazlani M. Ali
it depends on which meshing tool did you use.i guess you're using ansys meshing, you can do that under file -» export -» msh file.
By negative volume you mean -2.5e-03, just to make sure
Regards,
Ali
Old   May 31, 2012, 13:19
Jan
Hi Ali,
Please find the mesh file.
Yeah its 3.146130e-4.
Old   May 31, 2012, 13:58
diamondx's Avatar
Ghazlani M. Ali
your mesh is fine as i suspected 3.14e-4 is not negative !! -3.14e-4 is negative.
Right ?!!
Regards,
Ali
Old   May 31, 2012, 14:06
Jan
Is this figure acceptable?
I feel a litttle stupid now. Thought it had to be a higher Volume.
Old   May 31, 2012, 14:09
diamondx's Avatar
Ghazlani M. Ali
i think so. did you perform an analysis or not yet, depending on what your simulating you may need to refine your grid. but for now it's ok. get back to us with some results.
Regards,
Ali
Old   May 31, 2012, 14:13
Jan
I did try but wasnt getting a solution. I thought it was because of the mesh.
Ill play around with the boundary conditions and see if i can work it out.
Thanks again
Negative Volume during Mesh Motion Analysis giov_ingr FLUENT 2 December 13, 2013 06:09
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
FSI & Negative Volume Mesh Mojtaba CFX 1 October 13, 2008 07:13
Negative volume in mesh motion skarp CFX 5 July 11, 2007 23:51
