[GAMBIT] 2D airfoil meshing help
Old   May 29, 2012, 09:14
Default 2D airfoil meshing help
abishai murday
ACER is on a distinguished road
Hi everyone..
Could someone please help me on meshing a 2Dairfoil in gambit...ive attached a boundary layer and used sizing functions at the trailing edge vertex and airfoil edges but i always keep having highly skewed meshes at the tip..even though i decrease the min size..i have tried everything kinda..is there something im missing??? i would really appreciate any kind of help and advise on hw to improve the mesh overall....
URL TO PICS
http://img819.imageshack.us/img819/7842/71402200.png
http://img823.imageshack.us/img823/9931/49230210.png
http://img600.imageshack.us/img600/2302/83140483.png
http://img51.imageshack.us/img51/1433/65923687.png
thank you
ACER is offline   Reply With Quote
Old   May 29, 2012, 09:31
-mAx-'s Avatar
Maxime Perelli
split your domain for having more control of your mesh.
For istance you can create an ellipse which surrounds your airfoil.
Split your domain with your ellipse. Be sure the ellipse has an hollow (your airfoil)
Now you can mesh your ellipse surface .
Old   May 29, 2012, 09:55
abishai murday
thanks for the reply Max...ill give this a try
thank you
Old   May 30, 2012, 13:10
abishai murday
Hi MAx
I have tried your suggestions but doesnt seem to work really...I have actually seeded each surface of my airfoil with up to 1000 seeds to be able to have a fine mesh near the region including a sizing function but still ending up with skewed meshes at the trailing edge...
thank you
Old   May 31, 2012, 00:44
-mAx-'s Avatar
Maxime Perelli
picture please
Old   May 31, 2012, 15:49
abishai murday
thanks again max for ure reply
heres the pic
ive made the inner box as close as possible to the airfoil but still gettin skewed that the end
http://img221.imageshack.us/img221/626/62801430.png
http://img205.imageshack.us/img205/7158/48309241.png
would really appreciate any kind of feedbackk
thank you
Old   June 1, 2012, 01:00
-mAx-'s Avatar
Maxime Perelli
your box is to close from airfoil
Use an ellipse instead of the box
Airfoil Meshing Scheme in Gambit J. Weiler FLUENT 6 October 2, 2011 15:41
[Other] Ansys meshing airfoil and / or compressor blades baw192 ANSYS Meshing & Geometry 8 September 23, 2011 00:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
Oscillating Airfoil - Dynamic meshing or user-defined velocity profile. DarrenC Main CFD Forum 5 July 19, 2010 22:33
[GAMBIT] Meshing airfoil using .dat file problem creggie ANSYS Meshing & Geometry 10 June 27, 2010 19:24
