-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [ICEM] Problem with mashing NACA0012 2D to 3D (http://www.cfd-online.com/Forums/ansys-meshing/102592-problem-mashing-naca0012-2d-3d.html)
natala1987 May 29, 2012 11:26
1 Attachment(s)
I've got big problem with NACA0012 meshing. I do not have experience with CFD and I really need your help;) I've done 2D mesh and it works in Fluent. Now I should create mesh in 3D with the same parameters (something like extrude for 0.2). I attache my 2D ICEM CFD file.
Thank you for your help;)
diamondx May 29, 2012 11:30
here is a link of a video tutorial on how to mesh a 3D wing made by Mr Far:
http://www.youtube.com/watch?v=mgjRT4WY_iA
hope it can help
natala1987 May 29, 2012 11:35
http://sendfile.pl/171206/NACA0012.zip
http://sendfile.pl/171207/NACA0012_2.zip
Far May 29, 2012 12:30
This option works fine, if you want to simulate the 3d effects for 2d case (quasi 3d with symetry condition on both sides of wing). But if you really want the 3d wing mesh, that is meshing is also going after the wing and also inside the airfoil block exteded in the 3d then you should start with the 3d blocking and or you can make the 2d blocking and revolve it (as pointed by Simon and I am quoting exact words below)
There are several ways to handle a 3D wing. This one's key features are a sharp trailing edge (which suggests a C Grid) and a flat wing tip, which is most easily captured with (Blocking => Create => 2D to 3D).
Start with a 2D blocking... But because you will need to keep the flow volume past your wing tip, you also need to mesh inside the airfoil. The topology Far showed works well, or if you can handle wedges in your model, you could just keep the very simple collapsed block you got from collapsing the blocks behind the trailing edge, then add the Ogrid to the front inner block of the airfoil.
Then go to Create Blocks => 2D to 3D and choose the "by translation" option. Put in the width of your box and apply.
Then go and "delete" the blocks that should end up inside the airfoil (or put then in a solid blocking material).
Associate all the edges with the 3D curves, set up edge parameters, etc.
Done.
Detailed procedure is discussced here and diamondx already proivded you the link for YouTube video.
http://www.cfd-online.com/Forums/ans...mesh-wing.html
Blocking is also attached with above post for four different procedures. If you still find it difficult, let us know and we shall help you out.
Far May 29, 2012 12:32
I am also going to add the voice in these videos soon.
natala1987 May 29, 2012 14:06
Thanks ;) I am going to do it tomorrow and I will let you know ab.results ;)
PSYMN May 31, 2012 09:50
Just to be clear, it is possible to extrude the blocking or the mesh (2.5D), but Far is assuming that you are actually trying to mesh a real 3D wing with a wing tip...
If you really want to mesh the full wall to wall airfoil, extruding what you already have is the easiest way.
Best regards,
Simon
natala1987 May 31, 2012 10:29
My wing is symmetry so "extrude" is easier way than create geometry, blocking...I had problem with "extrude" because my boundary conditions did not work in Fluent, but I solved a problem. Before "extrude mesh" necessary is tick "lines" in mesh tree. Mesh and boundary conditions are working and results of lift and drag coefficient are the same as experimental results ;)
Far May 31, 2012 10:34
Actually, if you are trying to include the 3d effects then extrude is the best option. However if you want to solve the 3d wing then you need to consider the 3d blocking.
Can you post the few pics of goemetry, mesh and results.
natala1987 May 31, 2012 10:46
No problem but tomorrow, becuse I've back from university ;)
natala1987 June 1, 2012 04:40
4 Attachment(s)
I can send you few print screens of my mesh. In 3D case I have 4 layer (every one 0.05). It is not too much but it is enough to compare with experimental results. In the next part I will simulate accretion of icing on the airfoil.
I am not sure what mean Area and Length in references value in Fluent? could you help me?
Far June 1, 2012 05:07
Are you taking 30% of chord to extrude airfoil in 3rd direction? Four nodes may be sufficient I am not sure. Length is air-foil chord and area is the chord * unit because you are simulating the 2d airfoil
Model top and bottom wall with slip condition (zero shear) and dont apply pressure far field.
natala1987 June 1, 2012 05:19
I am confused ;/ I should talk with my supervisor. So in your opinion which depth will be the best, 1?
In 3D case to compute area I should multiply chord *depth?
Far June 1, 2012 05:59
depth should be 0.3*chord to 0.4*chord for the 2d cases with 3d effects. I have learned it from the research paper.
Since you are simulating the 2d cases, therefore you should take the 2d properties to normalise the data.
