[ANSYS Meshing] Growth ratio with body sizing
Old   October 11, 2012, 19:55
Default Growth ratio with body sizing
saisanthoshm88 is on a distinguished road
When I use a body sizing with a growth rate in ansys meshing for a tet prism mesh I get a uniform mesh in the flow volume and I couldn't see any effect of the growth rate set with the body sizing.
Could some one please explain this.
In case the growth rate doesn't work with a body sizing then I'm thinking of removing the body sizing and instead select all the faces and set a face sizing equal to body sizing.
Can this be a better approach for the growth rate to show up into the volume.
Best regards,
Santhosh.
saisanthoshm88 is offline   Reply With Quote
Old   October 12, 2012, 07:51
Yes I've tested it and found that the approach of choosing face sizing works better in having the desired growth rate.
Best regards,
Santhosh.
Problem with divergence TDK FLUENT 13 December 14, 2018 06:00
6DOF with floating body bounce back. paka FLUENT 4 June 6, 2013 11:32
pressure eq. "converges" after few time steps maddalena OpenFOAM Running, Solving & CFD 69 July 21, 2011 07:42
diesel spray combustion equivalence ratio usker Siemens 12 March 1, 2008 06:09
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 06:13
