[ANSYS Meshing] Importing Cylinders by Point Data Input with Radii
Old   May 29, 2012, 15:27
Default Importing Cylinders by Point Data Input with Radii
Brian Henry
EphemeralMemory is on a distinguished road
Hello, thank you for reading this,
Something I have tried in the past is the importing of point and connectivity data into Ansys using the Formatted Point Input. I can successively import the points easily, but I was wondering if I can progamatically import cylinders using a similar approach. I am doing this in ANSYS ICEM CFD at the moment.
I have the beginning point, end point and radii for each segment. When I imported point data before, I built cylinders completely manually, but the tree I have this time is made up of hundreds to thousands of segments, so it would be a lot easier if I could programatically bring them in.
I understand this is possible using a TCL script. How would I look into writing one, and where would I execute the script?
Thanks for your help!
EphemeralMemory is offline   Reply With Quote
Old   May 31, 2012, 09:56
Default ICEM CFD Scripting
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Go to File => Replay Scripts => Replay control and record the steps you want to script... So go into point creation, create your points, then go into surface creation and create cylinders from those points...
Looking at your replay script, you will see the command for each of those operations. For more details about the structure of each command, go to Help => Programmers guide and look them up.
Then you can create a replay script using these commands and other tcl logic (some other help is given in the programmers guide) to setup loops, if statements, etc.
You can run the script a variety of ways, including in batch.
To run it in batch, run icemcfd -batch scriptname.rpl
It would be cool if you could post your final script here so people could learn from your experience.
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   May 31, 2012, 13:34
Brian Henry
Thank you very much, will take a look in to this!
You are my favorite PSYMN for today.
Transfer output data as input for second calculation mannobot Main CFD Forum 3 December 7, 2018 09:37
input data to a poisson solver HaKu Main CFD Forum 2 June 11, 2009 22:45
Text input commands to add data points Kathryn FLUENT 0 November 5, 2007 17:38
how to create the formatted point data for icemcfd charles CFX 3 February 28, 2006 20:01
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
