[ICEM] Problem with mashing NACA0012 2D to 3D |
May 29, 2012, 11:26 |
Natalia
Rep Power: 13 |
I've got big problem with NACA0012 meshing. I do not have experience with CFD and I really need your help I've done 2D mesh and it works in Fluent. Now I should create mesh in 3D with the same parameters (something like extrude for 0.2). I attache my 2D ICEM CFD file. Thank you for your help |
May 29, 2012, 11:30 |
Ghazlani M. Ali
Rep Power: 28 |
here is a link of a video tutorial on how to mesh a 3D wing made by Mr Far:
http://www.youtube.com/watch?v=mgjRT4WY_iA hope it can help |
May 29, 2012, 11:35 |
Natalia
Rep Power: 13 |
May 29, 2012, 12:30 |
#4 | ||
http://www.cfd-online.com/Forums/ans...mesh-wing.html Blocking is also attached with above post for four different procedures. If you still find it difficult, let us know and we shall help you out. |
May 29, 2012, 14:06 |
Natalia
Rep Power: 13 |
Thanks I am going to do it tomorrow and I will let you know ab.results
May 31, 2012, 09:50 |
Simon Pereira
Rep Power: 47 |
Just to be clear, it is possible to extrude the blocking or the mesh (2.5D), but Far is assuming that you are actually trying to mesh a real 3D wing with a wing tip...
If you really want to mesh the full wall to wall airfoil, extruding what you already have is the easiest way. Best regards, Simon
----------------------------------------- Please help guide development at ANSYS by filling in these surveys Public ANSYS ICEM CFD Users Survey This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)... CFD Online Users Survey |
May 31, 2012, 10:29 |
Natalia
Rep Power: 13 |
My wing is symmetry so "extrude" is easier way than create geometry, blocking...I had problem with "extrude" because my boundary conditions did not work in Fluent, but I solved a problem. Before "extrude mesh" necessary is tick "lines" in mesh tree. Mesh and boundary conditions are working and results of lift and drag coefficient are the same as experimental results
May 31, 2012, 10:34 |
#9 |
Actually, if you are trying to include the 3d effects then extrude is the best option. However if you want to solve the 3d wing then you need to consider the 3d blocking.
Can you post the few pics of goemetry, mesh and results. |
May 31, 2012, 10:46 |
#10 |
Natalia
Rep Power: 13 |
No problem but tomorrow, becuse I've back from university
June 1, 2012, 04:40 |
#11 |
Natalia
Rep Power: 13 |
I can send you few print screens of my mesh. In 3D case I have 4 layer (every one 0.05). It is not too much but it is enough to compare with experimental results. In the next part I will simulate accretion of icing on the airfoil.
I am not sure what mean Area and Length in references value in Fluent? could you help me? |
June 1, 2012, 05:07 |
#12 |
Are you taking 30% of chord to extrude airfoil in 3rd direction? Four nodes may be sufficient I am not sure. Length is air-foil chord and area is the chord * unit because you are simulating the 2d airfoil
Model top and bottom wall with slip condition (zero shear) and dont apply pressure far field. |
June 1, 2012, 05:19 |
#13 |
Natalia
Rep Power: 13 |
I am confused ;/ I should talk with my supervisor. So in your opinion which depth will be the best, 1?
In 3D case to compute area I should multiply chord *depth? |
June 1, 2012, 05:59 |
#14 |
depth should be 0.3*chord to 0.4*chord for the 2d cases with 3d effects. I have learned it from the research paper.
Since you are simulating the 2d cases, therefore you should take the 2d properties to normalise the data. |
icem 3d |
conduction problem | venkataramana | OpenFOAM | 3 | December 1, 2013 07:30 |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Problem with airflow over naca0012 and angle o f attack | Lucas | OpenFOAM Running, Solving & CFD | 2 | February 18, 2011 13:13 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
