Home > Forums > ANSYS Meshing & Geometry
[ICEM] Meshing a skewed object at low solidity
Old   June 17, 2012, 14:13
Default Meshing a skewed object at low solidity
KB
Benrode is on a distinguished road
1)I am trying to mesh a windmill blade, with low solidity(i.e. spacing smaller than the width of the chord. ) at a pitch angle of about 22. The trailing edge is skewed I realise using blocking for the mesh will not represent the fluid at the trailing edge very well.The mesh also has to be periodic at the top and bottom boundaries. I have a sample of the preliminary mesh attached. Can anyone advise on the best approach to this.
Thank you
Benrode is offline   Reply With Quote
Old   June 17, 2012, 18:00
Khayyamian
hadikhayyamian is on a distinguished road
I recommend to use an O-grod around the blade, this causes to mange the leading and trailing edge more precisely.
see this for example
turbine blade meshing
hadikhayyamian is offline   Reply With Quote
Old   June 17, 2012, 21:46
KB
Thanks, I actually used o-grid when I had high solidity or when the airfoil was treated as an isolated one. There was no problem generating the mesh and capturing the flow. However, when the spacing becomes smaller and it is at a pitch angle other than zero it became difficult to use o-grid.Find attached the a surface mesh of the problem, the only thing in this case is i could not get periodicity.
Thread Tools
Trackbacks are On
[ANSYS Meshing] Can I use ANSYS Meshing for manual meshing? Kirjain ANSYS Meshing & Geometry 6 November 30, 2015 09:11
[ANSYS Meshing] How to get rid of skewed elements while meshing a pipe with many interfacing surfaces everdimension ANSYS Meshing & Geometry 6 October 2, 2014 23:45
problem meshing with low y+ cesco FLUENT 8 February 23, 2009 06:12
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
Singularity of grid?Volume meshing vs face meshing Ken Main CFD Forum 0 September 4, 2003 11:09
