Home > Forums > ANSYS Meshing & Geometry
[DesignModeler] Modifying Parasolid Files in DM
Old   June 20, 2012, 06:50
Default Modifying Parasolid Files in DM
peterputer is on a distinguished road
Hej,
I ve got a Parasolid File out of a CAD model which i imported in Design Modeler. Is there any possibility to change geometry of that imported file, like adjusting lines etc?
Regards
peterputer is offline   Reply With Quote
Old   June 20, 2012, 07:41
Far
Sijal
Far will become famous soon enoughFar will become famous soon enough
Send a message via Skype™ to Far
This can be done easily in spaceclaim. If you can send files / connect through my teamviewer and change files yourself. But this can be done easily in dm...
Far is offline   Reply With Quote
Old   June 20, 2012, 07:56
I can change the parasolid in UG NX as well, but then i ve to export it as a parasolid file and import it as a new geometry in DM again, so that i ve new bodies and ve to start my simulation from scratch.
So i ve to modify my parasolid model in DM :/
Old   June 20, 2012, 09:07
Ok i solved it, if i select the face of the parasolid model and click sketch afterwards, it generates a sketch on that surface and i can at least select lines of that face. enough for my purposes.
Regards
Old   June 20, 2012, 09:08
Far
Sijal
then spaceclaim should be the only choice. Is is coupled with ANSYS
Old   June 20, 2012, 09:29
Ok i googled spaceclaim didnt know about it. Seems to be pretty useful, anyway for what i needed i found a work around, which fits my needs.
Ty anyway
Thread Tools
Trackbacks are On
UDF issue MASOUD Fluent UDF and Scheme Programming 14 December 6, 2012 14:39
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 03:01
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 08:21
OpenFOAM15 paraFoam bug koen OpenFOAM Bugs 19 June 30, 2009 10:46
