2 Bodies with own Mesh
Hey guys,
(got Ansys workbench 14) i would like to make 1 Body sperated in some parts (in example 2). I extruded 2 sketches and made them frozen. Then i used Form new Part. So both parts should be one. I'll do some stuff with fluent after and fluent should interpret this as 1 Body. http://i46.tinypic.com/izbwx1.jpg I've done this cause i want to use the Surface of the smaller square as an inlet. Futhermore i want to have more cells in the smaller square. Hope this way is corret? Or are the other better soultions to do this? Hope i made this clear :rolleyes:. Already read so much Manuals and searched at google but didnt found something usefull ) Nevermind got new Problem: I got 2 two cubes/Parts of my Bodiy and make them as fluid for my fluent. The smaller cube getting his own interior and his own walls, which i dont want cause both cubes should be handled as one. Any help? If i make them both as solid, i just get 1 wall and interior.... but i want fluids.. what exactly change at all if i change fluid/solid in design modeler? Thanks guys |
Sorry, not sure what your revised question is asking for...
If you want two fluid zones in one multi-body part, the mesher will make sure the mesh is conformal, but it will still have an interface surface between the two zones. |
Hey ok, forgot all things i said.
made new example and i hope this will make it clear: what i've done: http://i48.tinypic.com/jjqw4n.jpg http://i48.tinypic.com/1z6ehib.jpg http://i49.tinypic.com/25it1nd.jpg as you can see iam getting 2 cell zone conditions, which i dont want - i want 1. The body i created should be treated as 1 body. Same with the walls (2 walls , 3 interiors). Can someone help? Thanks!! i already managed to do this but cant reproduce.. |
