Home > Forums > ANSYS Meshing & Geometry
[ICEM] Tetra + prism turbine blade
Old   June 21, 2012, 10:07
Default Tetra + prism turbine blade
Sarah4
sarah4 is on a distinguished road
Hello, I am using Tetra + prism method to mesh fluid domain around a turbine blade.I have got good elements except around the tip and the root(see pics). I tried to smooth(first tetra then prism and tetra together),but even worse quality appeared.
Can anybody share any experience about this kind of cases? What is the difference between tick on and tick off the Laplace smooth function?I always got worse quality with it on.
Or the bad elements could be due to other factors?
Any advice is welcome.
sarah4 is offline   Reply With Quote
Old   June 21, 2012, 11:28
Far
Sijal
Far will become famous soon enoughFar will become famous soon enough
Send a message via Skype™ to Far
For these type of cases ICEM Hexa is the best choice...
Far is offline   Reply With Quote
Old   July 1, 2012, 06:41
Sarah4
Hello Far,
Thanks for your reply.
It is difficult to get a good quality using tetra+prisms while the boundary layer mesh goes too fine.
I have also tried ICEM hexa, using o block +split at the trailing edge, but resulted bad cells again around the sharp trailing edge .I have seen your video on youtube"wing with sharp trailing edge". I must missed something. I do not know if you could look at my problem here.
Old   July 1, 2012, 06:59
Far
Sijal
Ya you missed the o-grid in front half of leading block (inside) and Y block in aft tip block
Old   July 1, 2012, 08:43
Sarah4
Is this what you mean? but i still got bad cells...
Old   July 1, 2012, 08:45
Far
Sijal
I didn't get you. Could you please elaborate more?
Sarah4
Sorry pic here
Old   July 1, 2012, 08:46
Far
Sijal
did you convert the wedge block into yblock?
Old   July 1, 2012, 08:49
Sarah4
Yes tried
but it seemed that it cannot be converted. "number of degenerate corner !=2"
Old   July 1, 2012, 08:50
Far
Sijal
send files at turboenginner@gmail.com and/or attach to this forum.
Old   July 1, 2012, 08:59
Sarah4
I realised that this is not a wedge block. ..it has 8 corners so cannot be converted
Old   July 1, 2012, 09:00
Far
Sijal
merge vertices at trailing edge (i hope you have sharp trailing edge)
Old   July 1, 2012, 09:11
Sarah4
Thanks for your video and quick reply here.
Thread Tools
Trackbacks are On
[ICEM] Fixing tetra Surface Orientations after prism generation siw ANSYS Meshing & Geometry 14 December 1, 2015 16:54
[ICEM] Tetra mesh quality before and after prism layer Chander ANSYS Meshing & Geometry 0 December 25, 2011 23:04
Calculating lift force of a wind turbine blade problem LittleBart CFX 4 June 29, 2011 02:33
force acting on gas turbine blade.... vvj Main CFD Forum 1 March 3, 2010 02:04
Wind Turbine Blade Geometry SeanieB Main CFD Forum 0 November 27, 2009 11:18
