Home > Forums > ANSYS Meshing & Geometry
[ANSYS Meshing] Meshing Advice ??
Old   June 22, 2012, 23:31
Default Meshing Advice ??
Danial
Danial Q is on a distinguished road
Could anyone please give me advice for meshing in this case, where I have two domains (fluid, solid). I am solving Eulierian homogenous phase, free surface is involoved and thermal energy model is employed also. So need a very fine mesh as domains are of micron sizes too and i have to capture phase change at domain interfaces.
I have attached pic below.
Thanks in advance
Danial Q is offline   Reply With Quote
Old   June 23, 2012, 14:33
Retired from CFD Online
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
You could do it with a sweep or MultiZone mesh (probably would do that automatically anyway).
To control the distribution, switch the selection tool to select edges, then pick the 4 edges (hold down ctrl) perpendicular to the interface and insert method => Sizing. Setup some sort of edge biasing so the mesh will refine as it approaches the interface...
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   June 25, 2012, 01:02
Default HI
Danial
I have used sweep method and edge sizing. But after many tries ,the meshing window(small progress window) is stuck at the same point for almost like 14 hrs .
Could you please have a look at parameters and locate the error or unnecessary tighter parameters?
Thanks
Old   June 27, 2012, 02:16
Gweher's Avatar
Gwenael H.
Gweher is on a distinguished road
Could you please add your .agdb file
Gweher is offline   Reply With Quote
Old   June 27, 2012, 07:08
Default Hi
Danial
I have done sweep meshing but was unable to do edge sizing for unknown reasons. It got stuck somewhere when i selected Hard behavior with BIAS >>ON and BIAS factor 1.
Now the worry is, i have 8 million elements and my system needs multiprocessor. so the question is, should i do meshing again with less element size.would it work???
Old   June 27, 2012, 20:25
Gweher's Avatar
Gwenael H.
I never encountered that error, but did you try to assign the edge sizing before adding the sweep method? Cause I did a quick cube of 20 microns edge size and assigned 100 elements in each direction, so a total of 1M and it took less than 10min (I have a 16gb Z210 workstation). You should try edge sizing first and then use mapped face, compute the surface mesh and then generate the volume mesh.
Regarding the multiprocessor did you assign multiple CPU in the Ansys Meshing Options (under >Tools>Options>Meshing) ?
Old   June 27, 2012, 23:51
Default Hi
Danial
No, i did not assign multiple CPU, glenn told me that it was not issue of CPU but CFX SOLVER capability. Anyways, could you please explain how did you set 100 elements, because I have option edge size element. No, I did sweep meshing first and then edge sizing.
Old   June 28, 2012, 00:06
Gweher's Avatar
Gwenael H.
Well under >Sizing>Definition>Type you can choose between :
- Element size
- Number of divisions
- Sphere of influence
I assigned 100 elements using Number of divisions under >Type (see attachment)
Have a try assigning Sizing first and then sweep.
And yes, I forgot for the SMP it depends on the method that you are using, sorry.
Old   June 29, 2012, 00:30
Default HI gweher
Danial
I have generated this mesh (attachments) and please comment on mesh statistics;
Mesh Statistics |
| Domain Name | Orthog. Angle | Exp. Factor | Aspect Ratio |
| | Minimum [deg] | Maximum | Maximum |
| splat | 90.0 OK | 2 OK | 53 OK |
| substrate | 38.7 ok | 6 ok | 37 OK |
| Global | 38.7 ok | 6 ok | 53 OK |
| | %! %ok %OK | %! %ok %OK | %! %ok %OK |
| splat | 0 0 100 | 0 0 100 | 0 0 100 |
| substrate | 0 3 97 | 0 <1 100 | 0 0 100 |
| Global | 0 <1 100 | 0 <1 100 | 0 0 100 |
Old   June 29, 2012, 02:23
Far
Sijal
Far will become famous soon enoughFar will become famous soon enough
Send a message via Skype™ to Far
seems good
Far is offline   Reply With Quote
Old   June 29, 2012, 06:04
Default HI
  #11
Danial
Could you please explain that how can I set the number of cells for meshing as I have some parameter like " 20 cells per 20microns". This parameter gives some grid independent results for my model. What is that supposed to mean?
Old   June 29, 2012, 06:52
Gweher's Avatar
Gwenael H.
Well if your results are grid independent with that parameter for a particular setup then you do not need to continue refining your mesh for that case.
So you just need to generate your mesh according to the parameter you just mentioned in order to obtain grid independent results.
Old   June 29, 2012, 08:13
Default Hi gweher
  #13
Danial
All i have as information about meshing is "Hexagonal mesh (grid independent) with 20cells per initial dia of drop (i.e. 20 micron). So, Could you please mention where can i set this "number of cells" parameter. I am unable to find it or may be if it is something different than normal meshing then how to employ this.
Thanks
Thread Tools
Trackbacks are On
[ANSYS Meshing] Advice for meshing of corrugated tubes subsemitonium ANSYS Meshing & Geometry 16 March 4, 2016 03:49
Advice needed for meshing for wall functions zinger ANSYS Meshing & Geometry 0 April 22, 2009 23:09
DES and LES meshing: tips and advice? James M Main CFD Forum 3 June 27, 2007 13:43
DES and LES meshing: tips and advice? James M FLUENT 3 June 24, 2007 20:22
Turbulence Model and Meshing Advice Jason FLUENT 1 January 31, 2006 14:05
