[ICEM] create Part
Old   June 27, 2012, 13:00
Default create Part
yang
wangy1767 is on a distinguished road
Dear all,
I have a question about PART creating.
For one surface, we called a wall, this wall includes other surfaces e.g. inlet etc. The question is I create a Part for the Inlet surface, I want to create another Part for the rest area of this Wall except this Inlet area, How to set this Part for the rest area of this Wall?
Please tell me the detailed step for this Part creating.
Many thanks in advance!
wangy1767 is offline   Reply With Quote
Old   June 27, 2012, 13:49
cfd seeker is on a distinguished road
Right click on "PARTS" and go to "CREATE PARTS"....after creating inlet surface turn it off under the "PARTS" tree and again go to "CREATE PARTS" and select rest of surfaces and name it accordingly. Hope it helps you
Regards
cfd seeker is offline   Reply With Quote
Old   June 28, 2012, 04:05
yang
Regards
Dear Madam or Sir,
Many thanks for your quick reply!
I already tried this method indeed, however, after turning inlet surface Part off, the wall still includes all the surface area. I don't know why. I really need select rest of surfaces as another Part called Wall.
Old   June 28, 2012, 04:44
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
You need two step procedure.
First split the your main part into two parts by using the split with edge
then right click on parts and make the two parts.
Far is offline   Reply With Quote
Old   June 28, 2012, 04:55
yang
Dear Far,
Since I am a new member, Please tell me how to "use the split with edge" and other steps in detail?
PLUS: I didn't use the BLOCK, and it is only for the Geometry.
This surface is normal surface not faceted surface, i think.
Old   June 28, 2012, 05:17
Far
Sijal
Can you show your geometry please. If possible attach the tin file.
Old   June 28, 2012, 05:29
yang
Please see the attached image. I want to define 2 Parts, one is outlet, another is wall except outlet surface area. Now the wall always includes the outlet surface.
The small yellow one is outlet.
Thanks in advance!
Old   June 28, 2012, 05:39
Far
Sijal
tin file please.
For quick work around, go to the geometry>>> surface>>>> (in 2nd row) split by edge. Select the surface and edge and apply you will get two surfaces. then right click on part >>> crate part and define them separately.
Old   June 28, 2012, 07:11
yang
tin file please.
Many thanks!
Please pass me your email address, I can't transfer into the zip file or upload tin file in cfd online forum.
For split by edge, I only find "Segment Surface" in surface no split by edge.
Old   June 28, 2012, 08:05
Far
Sijal
yes it is the command... email : turboenginner@gmail.com
Old   June 30, 2012, 18:46
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
From the image, it looks like the two surfaces are already in different parts (which is why you see them in different colors).
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
[ICEM] Part for Inlet or Outlet wangy1767 ANSYS Meshing & Geometry 4 June 5, 2012 07:48
[DesignModeler] Newbie - Create Region 5746085 ANSYS Meshing & Geometry 2 March 12, 2012 13:15
[DesignModeler] How to create smaller pipe inside bigger pipe? Munggang ANSYS Meshing & Geometry 2 March 7, 2012 14:01
Actuator disk model audrich FLUENT 0 September 21, 2009 07:06
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 01:07
