July 1, 2012, 06:14 |
Perforated plate distributor
Musango Lungu
Dear Friends I am modeling a 2D fluidized bed reactor and I would like to create a perforated plate distributor in the geometry using Gambit. However I do not know how to about it. Kindly help!perforated plate.JPG
July 2, 2012, 01:10 |
Maxime Perelli
Rep Power: 41 |
do you want your flow entering directly from holes, or do you want an upstream flow with shrinkage at holes?
what is the dimensions of your perforated plate?
In memory of my friend Hervé: CFD engineer & freerider |
July 2, 2012, 01:21 |
Musango Lungu
Hi Max, yes I want the flow to enter directly from the holes.The fluidized bed has 150 mm inner diameter and 1000 mm height. The perforated gas distributor has a pore diameter of 2.0 mm and an open area ratio of 2.6 %.
July 2, 2012, 01:37 |
Maxime Perelli
Rep Power: 41 |
In 3D for keeping the 2.6% open ratio you need 145 holes with ř2mm.
What would be your geometry in 2d?
July 2, 2012, 02:41 |
Musango Lungu
I have no idea max. I will be grateful for your help.
July 2, 2012, 04:22 |
Maxime Perelli
Rep Power: 41 |
I would handle the problem in 3d, and use 2 symmetry-planes (quarter)
Perforated plate | franzdrs | Main CFD Forum | 16 | November 12, 2017 05:48 |
Modeling of perforated plate for 3 phase fluidized | Sanyo | FLUENT | 5 | March 27, 2015 11:01 |
Need help on perforated plate with less than 2% open area | sosososo1114 | FLUENT | 9 | August 31, 2011 01:33 |
flow in perforated pipe distributor | pertupd | ANSYS | 0 | August 12, 2009 08:36 |
turbulence at a porous jump (perforated plate) | andrew | FLUENT | 1 | May 8, 2004 09:51 |
