-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [ANSYS Meshing] Abrupt Contraction: Meshing and Boundaries (http://www.cfd-online.com/Forums/ansys-meshing/104030-abrupt-contraction-meshing-boundaries.html)
Kirjain July 2, 2012 06:45
1 Attachment(s)
Hi all,
I am trying to mesh an abrtupt contraction in a pipe (3D) with solely hexahedral elements whilst still maintaining good orthogonal quality. Due to the automatic meshing system of Ansys Meshing the mesh does not behave the way I would want it to and I would need help in optimising it. I added a picture of the current mesh as a thumbnail.
Furthermore I would need assistance with the boundary conditions of the system as I do not know how to treat the contraction walls as impervious. I chose all the outer faces (except inlet and outlet) as a named selection and set the velocity in Fluent to be 0 m/s on the boundary but still after calculation the plots showed fluid gushing out of the annular face at the contraction.
Thank you for your help!
Gweher July 3, 2012 01:38
If you want to have more control with AM then one option is to slice your geometry into sub-parts so that the meshing tool could handle it like you expect your mesh.
You can either slice by plane of with sketches depending on the complexity of your model.
If you can attach your .agdb file so that I can have a look.
Far July 3, 2012 02:06
This is the very simple case for ICEM CFD
