[Other] Conversion gtm to msh
Old   July 3, 2012, 16:15
Default Conversion gtm to msh
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
Is it possible to convert a GTM (CFX) file to MSH (FLUENT)
I only have the gtm file, i didn't do the meshing, therefore i'm not able to export in msh or save under msh file.
Thanks in advance
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   July 3, 2012, 18:55
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
you can import the gtm file in fluent. which can be saved in .cas format but not .msh
Far is offline   Reply With Quote
Old   July 3, 2012, 18:57
diamondx's Avatar
Ghazlani M. Ali
thanks far. but i couldn't import it in fluent. i only have choice for res and something else, not the gtm.
Regards,
Ali
[Salome] Mesh conversion Salome to OpenFOAM VMartinez OpenFOAM Meshing & Mesh Conversion 11 April 21, 2014 02:54
msh format Frank FLUENT 1 June 27, 2012 10:39
[Commercial meshers] Problem with Mesh conversion Gambit msh Foam Rachid BANNARI (Bannari) OpenFOAM Meshing & Mesh Conversion 25 September 11, 2011 07:58
Mesh conversion exits prematurely (Salome to OF) DMcP OpenFOAM 0 July 14, 2011 02:07
[Commercial meshers] Several problems with the mesh conversion utility when converting the meshes from Gridgen su_junwei OpenFOAM Meshing & Mesh Conversion 2 July 26, 2008 23:58
