[ANSYS Meshing] To ask a question about O-grid generation |
July 9, 2012, 15:50 |
Why don't we use domain interface to solve this problem?
lnk
Rep Power: 15 |
May I ask you a question about O-grid generation? Here is a picture. I'd like to generate a picture like B. But since I can't rotate my block, I always obtain A. How to solve this problem? Best regards and many thanks, lnk Last edited by lnk; July 18, 2012 at 16:35. |
July 9, 2012, 17:20 |
lnk
Rep Power: 15 |
Here is the problem. The geometry I'd like to mesh is a connection of a tube with a cube. If I have the O-grid like A, I can't correct the bad quality meshes at the connection part of the tube and cube. So I try to rotate the O-grid to solve this problem.
Best regards and many thanks, lnk |
July 10, 2012, 05:38 |
AB
Rep Power: 21 |
just create points at the 2 exits of your model and associate the vertices of your o-grid to modifiy its shape. Then align the internal vertices of your o-grid with the vertices of the 2 exits of your model and you are all good !
July 10, 2012, 07:30 |
#7 | |
lnk
Rep Power: 15 |
Best, lnk Last edited by lnk; July 11, 2012 at 06:15. |
July 10, 2012, 09:10 |
lnk
Rep Power: 15 |
What do you mean by 'exits'? Won't that change my geometry?
July 11, 2012, 00:50 |
#9 |
Ghazlani M. Ali
Rep Power: 28 |
Far, Broly. this geometry is not easy...very tricky... i've been fighting with it for more than 4 hours now.i thought may be li's strategy for blocking was incorrect, so i erased his blocking and tried to came up with a better one using bottom-up approach. I couldn't, then i came back to li's blocking, realized that he can never get a good quality because he needs ygrid when the arc's circle meets the tangent line, alse noticed that geometry needs some cleanup, there are additional surfaces inside (tube), maybe that's why. I don't understand why and how li did that blocking... i need a break. i hope i can wake up the morning and find your approaches...
@li i'll come back to your geometry tomorrow to finish it... i saw another thread where you're asking about ygrid, you have to merge before, and select the triangular shape, but i just don't know how you can do that with your blocking... |
July 11, 2012, 05:47 |
#11 |
AB
Rep Power: 21 |
Those kind of geometry are hard because your circle geometry meet the corner of a rectangular shape. So I think you can avoid bad elements at the intersection of those 2 shapes.
I don't have much type to take a look at the geometry, will try this week :S |
July 11, 2012, 06:40 |
#12 |
AB
Rep Power: 21 |
Ok finally, I took some time to have a look.
Attached an example of blocking. you only need to do the association and maybe improve the position of some vertices. You can't avoid some bad elements between the corner of your rectangle and the print of your tube, but 1/4 of O-grid help to handle it. |
July 11, 2012, 07:48 |
#13 | |
lnk
Rep Power: 15 |
I tried that but I can't improve the quality because of the same reason. The quality at the attachment is the best I can do. |
July 11, 2012, 08:28 |
#14 |
AB
Rep Power: 21 |
You can incraese the number of nodes, move the vertices in order to optmize the blocking. But you have to know that at some point, you won't be able to improve the mesh because of your geometry.
July 11, 2012, 08:41 |
#15 |
lnk
Rep Power: 15 |
Yes. That's the problem. I can't make all my meshes have quality over 0.5.
July 11, 2012, 09:02 |
#16 |
AB
Rep Power: 21 |
Yep, but your biggest issue is not about the determinant, but about the min angle ... You can get a min determinant around 0.2, which is not that bad.
But there are few cells which min angle is between 0 and 9°, which could crash your solver ... If you work hard and moving the vertices of the 1/4 of O-grid, maybe you could improve a little bit your mesh ... Or maybe someone else could provide another blocking ? Have fun |
July 11, 2012, 11:21 |
#17 |
Alex
Rep Power: 46 |
You have to ask yourself one question:
Is it important that the geometric feature (the sharp angle) is represented by the mesh? Or wouldn't the flow field be almost exactly the same if the sharp angle is not represented by the mesh? In this case: change the geometry to allow better meshing. |
July 11, 2012, 11:30 |
#18 |
Ghazlani M. Ali
Rep Power: 28 |
The blocking is wrong...
@stief, that's exactly what i was thinking. you are right. Why do we have to follow the geometry ? how about something like this someone correct if i'm wrong... |
July 11, 2012, 11:59 |
#19 |
AB
Rep Power: 21 |
I correct some errors in the blocking (see attached).
And I fully agree with flotus |
July 11, 2012, 12:25 |
#20 | |
lnk
Rep Power: 15 |
I did in this way at the first time. It didn't work so I changed to make the mesh follow the geometry. The pipe is not inside the cube. It goes through the cube. If the mesh doesn't follow the geometry, the mesh will have problem at the connection part too which is, I think, also difficult to correct. You can see my attachments. It is even clear at the mesh picture. Best, lnk |
Display Modes | |
Grid Generation | Raghunandan K.V. | Main CFD Forum | 2 | October 4, 2008 10:26 |
cartesian grid generation method | Abu Taleb | Main CFD Forum | 7 | April 14, 2001 10:49 |
Cartesian grid generation method | Abu Taleb | Main CFD Forum | 0 | April 8, 2001 13:15 |
Cartesian grid generation method | Abu Taleb | Main CFD Forum | 0 | April 8, 2001 13:03 |
grid generation help | zhe zhang | Main CFD Forum | 2 | November 12, 1999 23:48 |
