Home > Forums > ANSYS Meshing & Geometry
[ANSYS Meshing] Question about Y grid
Like Tree2Likes
  • 1 Post By cfd seeker
  • 1 Post By Far
Old   July 10, 2012, 15:07
Question Question about Y grid
lnk
lnk
lnk is on a distinguished road
When I use Y-grid generation button, why there's erro message 'number of degenerate corners!=2'? What does it mean and how to fix it? (I use ICEM.)
Best regards and many thanks,
lnk
lnk is offline   Reply With Quote
Old   July 10, 2012, 19:07
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
did you merge before ? i get that when my block is not a triangular shape
Regards,
New to ICEM CFD, try this document --> https://goo.gl/NEbygB
Ali
diamondx is offline   Reply With Quote
Old   July 11, 2012, 09:58
cfd seeker is on a distinguished road
Exactly if you are trying to convert a block which is not in triangular shape then you will get this error. First merge the vertices by any of the methods i.e Merge vertices directly or using a Collapse block method and then convert the block into Y-block.
Regards
cagri.metin.ege likes this.
cfd seeker is offline   Reply With Quote
Old   July 11, 2012, 10:05
Talking
lnk
lnk
Regards
Thank you. I get it!
Old   March 8, 2014, 12:59
cagri.metin.ege's Avatar
Cagri Metin
cagri.metin.ege is on a distinguished road
I collapse tail of blade but my mesh broken if you have any idea why it is happen, I ill be appreciate
cagri.metin.ege is offline   Reply With Quote
Old   March 8, 2014, 13:23
Cagri Metin
Regards
Old   March 8, 2014, 13:50
Far
Sijal
Far will become famous soon enoughFar will become famous soon enough
Send a message via Skype™ to Far
reassociate edges on the blade again. I guess it is some bug that after creating Y-block, associations get reset.
Far is offline   Reply With Quote
Old   March 9, 2014, 14:00
Cagri Metin
thank you for replies
Old   March 10, 2014, 01:28
Far
Sijal
your problem is solved?
Old   March 10, 2014, 04:37
Cagri Metin
no I stil try different associated line , but I cant, I think I do everyhing right
Old   March 10, 2014, 06:48
Far
Sijal
why it is not solved yet?
Delete all the association and do all the associations again.
Thread Tools
Trackbacks are On
MapFields to New Grid For Extreme Grid Deformations due to Body Motion albcem OpenFOAM 0 May 5, 2009 14:17
Grid Adaptation Suresh FLUENT 0 October 15, 2003 13:18
GRID TO GRID INTERPOLATION in FLUENT calogero FLUENT 3 June 4, 2003 08:32
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 05:59
Troubles modelling flow through a grid Hans Klaufus CFX 1 June 28, 2000 16:43
