-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [DesignModeler] Merge Surface Body and Solid Body (http://www.cfd-online.com/Forums/ansys-meshing/104539-merge-surface-body-solid-body.html)
prikeyma July 11, 2012 17:31
Is there a way to merge a surface body and a solid body using the tools in Design Modeler?
Thanks in advance.
nauman55 July 15, 2012 10:25
use enclosure feature with parts merge option yes
you can do that by using enclosure option and then before creating the enclosure selecting the merge part option as yes. let me know if problem is resolved.
regards
oewnce932c April 24, 2013 11:55
found your thread, because want to join two or more Surfaces in DesignModeler.
freeze is defenetly good, did't really understood why)
my solution was to use create-> Body operation -> type SEW -> and select solids. that work for me:cool:
found it here https://www.sharcnet.ca/Software/Flu...onfeature.html ctrl+f "sew"
mjthomp3 June 11, 2014 17:17
regards
after setting the tolerance to 0.15 from 0.0015 (the default) it worked!! so happy.....
FJSJ April 15, 2015 10:47
I know it has been a long time, but I would like to know if this is possible (I mean, Merge Surface Body and Solid Body). I have done what nauman55 shared with us but I couldn't get it. And, at the same time, "sew" tool is just for surfaces. So, is DM able to perform this action?
oewnce932c April 16, 2015 07:01
in DM is not possible to merge Surface Body and Solid Body
:eek:
