July 12, 2012, 09:26 |
CutCell Mesh & Inflation
Çağlar Coşkun
Rep Power: 14 |
Hello
I am trying to do a simulate the natural convection in a cavity, having a complex geometry. I used the new Cut Cell method to mesh the geometry. I need to use inflation layers to resolve the thermal boundary layers better. When I add the inflation layers, they create stair-stepping at various locations, and results a bad quality mesh. This causes convergence problems in Fluent. I decreased the stair stepping problem by adjusting advanced inflation settings, but couldn't prevent it. Any ideas? |
July 12, 2012, 15:33 |
Çağlar Coşkun
Rep Power: 14 |
I don't know how to use icem. Should I try? Is it better at handling complex geometries?
July 12, 2012, 15:36 |
Rule of thumb: For simple geometries use Ansys meshing and for complex cases use ICEM CFD.
ICEM CFD is very good at handling complex geometries. You should try it and you can also get very good help at this forum from experts including The Simon . |
July 13, 2012, 08:56 |
Simon Pereira
Rep Power: 47 |
Cutcel is really in a separate category within ANSYS Meshing, it should be able to handle your complex geometry (it was designed for automotive underhood which is as complicated as it gets).
Are you using version 14? There was a lot of work on Cutcel prism between 13.0 and 14.0 and I noticed it got a lot better at handling these things. Maybe post a picture so we can see what you mean. Typically, the mesher only allows prism stair stepping when you set your physics to CFD => CFX, so check that setting also.
----------------------------------------- Please help guide development at ANSYS by filling in these surveys Public ANSYS ICEM CFD Users Survey This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)... CFD Online Users Survey |
July 14, 2012, 08:44 |
Çağlar Coşkun
Rep Power: 14 |
Far and PSYMN, thanks for replies!
Here are some pictures of my mesh. In fact, in most parts of the geometry, there is no stair stepping. Instead of that, layers are compressed a lot. http://postimage.org/gallery/123kqsxo/ My min. mesh size is 4mm, and number of inflation layers is 5. PSYMN, it is not possible to change physics or solver preference if cutcell is active, as seen on pictures. |
July 16, 2012, 16:52 |
#7 | |
Simon Pereira
Rep Power: 47 |
I asked around in development for you and was told that they had a name for this (they called it the "corner shrink bug") and that it was sorted out back in May (therefore fixed in R14.5).
In the mean time, Quote:
July 16, 2012, 17:12 |
Çağlar Coşkun
Rep Power: 14 |
ah.. the gap factor is 2 in my mesh is it better to reduce it? I made it 2 because, in tutorials, it is written that increasing this value makes the inflation layers more compressed, thus reducing the stair stepping.
The other inflation parameters are as follows: max. height over base: 0.5 max. angle: 180 fillet ratio: 0.5 fix first layer: no inflation type: smooth transition What can you suggest about these settings? Thanks a lot for your help... Last edited by CaglarCoskun; July 16, 2012 at 17:30. |
July 16, 2012, 17:32 |
#9 |
Simon Pereira
Rep Power: 47 |
Give it a try and tell us if it works...
I am not so expert at this (yet) that I can diagnose it remotely.
October 22, 2016, 12:15 |
#10 |
nurjs
Rep Power: 10 |
Hello Simon,
I need your help in meshing my geometry. I using different types of meshes tetrahedron with inflation, very fine, take alot of time to convegence. cut cell but i fail to using inflation with it, ICEM good determinet and angle but it give me un expected results for Nusslet number. So i feel i west my time without gooe results please can you help me |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 06:21 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
[ANSYS Meshing] Inflation - Mesh Quality | saideepakb | ANSYS Meshing & Geometry | 0 | May 26, 2012 09:14 |
engrid -> save as .stl with boundarie codes | Zymon | enGrid | 31 | August 29, 2011 13:40 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
