[ICEM] Importing cambered airfoil geometry to ICEM CFD
Old   July 13, 2012, 06:49
Default [ICEM] Importing cambered airfoil geometry to ICEM CFD
Madhukara Putty
kotimari is on a distinguished road
HI,
I am trying to study the transient aerodynamics of a wind turbine airfoil.
For meshing, I am following the video tutorial posted on Youtube. According to the tutorial, the first line of the datafile should contain the number of points on either side of the airfoil, and the number of curves. It works well for a symmetric airfoil since it has equal number of points on either side. Obviously, it's not the case for a cambered airfoil. I tried an alternative: create separate datafiles for upper and lower portions, import the upper(or lower) file first, and merge the other one in the next step. This didn't work as the program crashed with the message "segmentation violation-exiting after doing emergency save".
However, in the first line of the datafile, if we mention a number which is
greater than than the total number of points in the geometry, then ICEM CFD plots just points (no curves or surfaces). We can manually connect these points to get two nice curves. Though it looks like a workable method, it's not very attractive. Is there a more elegant method to import cambared airfoil geometry to ICEM CFD?
Thanks
Madhu
kotimari is offline   Reply With Quote
Old   July 13, 2012, 19:07
Default Importing cambered airfoil geometry to ICEM CFD-Solved
Madhukara Putty
Solved this issue. Suppose you have 30 points on the upper section, and 27 on the lower. Trick is to repeat a point, say the trailing edge, three times in the lower section. In this way, you have same number of points on either section.
Old   July 16, 2012, 15:44
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Exactly the solution I was going to suggest ;^)
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Airfoil Tutorial in ICEM CFD Saima ANSYS Meshing & Geometry 1 June 21, 2010 18:47
flow over an airfoil 3d ( Geometry on icem cfd ) dfmona Main CFD Forum 0 April 13, 2010 23:32
EXTRUDE option in ICEM CFD Geometry Mohammad Faridul Alam CFX 4 October 25, 2007 17:47
after importing geometry from TecPlot(ansys cfd)?? empirer2002 Main CFD Forum 0 April 16, 2007 02:07
Importing geometry from Pro E to ICEM CFD V5.1 sac CFX 2 January 16, 2006 08:38
