-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [ANSYS Meshing] how to mesh multiparts as one body (http://www.cfd-online.com/Forums/ansys-meshing/104749-how-mesh-multiparts-one-body.html)
yahya July 14, 2012 19:52
1 Attachment(s)
I trying to mesh the flow inside a separator
I have a cylinder full of a fluid with two surface plates as internals
When i meshed it i found that each part was meshed alone
so i want to know to connect the meshing as one part
in order to notice the influence of the plate on the flow behavior
the attachment shows the separator that I'm meshing
Gweher July 16, 2012 00:13
Just form a single part in DesignModeler. In the outline tree, select all your parts under Part section, then right click >Form New Part, this will fix your problem ;)
yahya July 16, 2012 02:48
Thx alot i used it and it worked😃
