-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [DesignModeler] question (http://www.cfd-online.com/Forums/ansys-meshing/104903-question.html)
tmeysam92 July 18, 2012 07:53
question
HI ALL,
i have a simple question in design modeler.
i sliced a volume, then i meshed the parts.
the problem is that, when i import the mesh to fluent, the interface between parts will appear as wall.
but when i use split tool in gambit, and mesh the parts, in fluent the interface is virtual and is not wall.
what should i do in design modeler??
flotus1 July 18, 2012 08:02
Try forming an assembly from the two parts in design modeler.
tmeysam92 July 18, 2012 11:22
i have to slice the parts. beacuse i want to make hexahedral mesh.
if i assemble parts in desgine modeler, then i can not mesh each part separately.
flotus1 July 18, 2012 11:35
You have to freeze the part before you slice it.
tmeysam92 July 18, 2012 13:08
i know that the slice tool is used just for frozen body.
suppose that i have a cylinder. for having hexa mesh, i have to first slice the cylinder in for parts, then i use multizone tool in ansys meshing, and i make the hexa mesh except the center of the pipe( that it is not important for my case), then i import the mesh to fluent,
when i import the mesh in fluent, the contacts between body will appear as walls, but i want to have interior, know what should i do????
flotus1 July 18, 2012 13:52
This is odd.
When I do it like this, interior faces are created automatically in Fluent.
You could of course change the walls to interior in Fluent.
devalpandya November 19, 2012 06:18
hi did anyone find out a solution of creating interior face in designmodeler?
