[ICEM] Uncovered Faces
Like Tree5Likes
  • 3 Post By PSYMN
  • 1 Post By Lycket
  • 1 Post By PSYMN
Old   November 10, 2009, 14:22
Default Uncovered Faces
Jorge
Lycket is on a distinguished road
Hello everybody,
I'm drawing a mesh of a geometry made up of a fluid (air) and a solid, and what I want to mesh is the fluid but when I do a 2D mesh check I get an "Uncovered Faces" error. A tutorial suggests manually joining any conflicting nodes, but I have more than 3000....what should I do? The plan is to export this mesh from ICEM CFD to Fluent with a BC which if I let the program do a "fix" it considers it to be a solid shape with an interior mesh.
how can i fix it by keeping the boundeary conditions in every edge?
Thanks.
Lycket is offline   Reply With Quote
Old   November 11, 2009, 22:25
Default Hmm...
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
The uncovered faces error shouldn't happen with a 2D mesh. The equivalent should be "missing internal edges". Where are you doing your mesh check?
Basically, Uncovered faces means that you have volume elements with an exposed side. It should be covered by a shell or another volume element. Missing internal edges means that you have a 2D elements with an exposed side. It should be covered by a line element or another 2D element.
When you get either error (Uncovered faces or missing internal edges), you should push the [Fix] button. This will prompt you to select or type in a new part name. It will create shell elements (or line elements) to cover the "uncovered" faces (or edges) and put the new elements in the part name you selected. You will then have a valid boundary to take to Fluent and use as a wall or internal wall or whatever.
Simon
blgypeng, ppl20 and H.R.D. like this.
PSYMN is offline   Reply With Quote
Old   November 13, 2009, 09:49
Default Uncovered faces
Jorge
I think i solved the problem, I had forgotten to associate the edge to the curve...
Thank you
blgypeng likes this.
Old   November 13, 2009, 11:12
Default Oh yea...
PSYMN's Avatar
Simon Pereira
Oh, you were using hexa...
That is a common problem for fluent users who don't realize that Hexa only creates those boundary line elements if you associate with a curve. Usually, they complain about a null pointer error.
Glad you figured it out.
hadikhayyamian likes this.
Old   July 17, 2012, 20:17
Khayyamian
hadikhayyamian is on a distinguished road
I would like to delete the post! but I cant.
Last edited by hadikhayyamian; July 20, 2012 at 16:03. Reason: I would like to delete the post! but I cant.
hadikhayyamian is offline   Reply With Quote
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 09:01
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 01:08
[Technical] Uncovered faces found ???? hansel OpenFOAM Meshing & Mesh Conversion 5 July 10, 2009 14:05
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 10:37
