Quality of the ICEM mesh
2 Attachment(s)
HI, everyone!
I made a mesh in the ICEM, but I don't know if the quality of the mesh is good. could it can be used in the Fluent. The results is like this... Attachment 14634 Attachment 14635 THANKS! HUIHUI |
Hi, I work on CFX. For CFX, the mesh quality need to be above 0.5. I think for Fluent, it's quite the same. So in my view, you need to improve the quality. (P.S. My tutor told me that, for most of the problem we need to avoid using tetra mesh as much as possible to have the accurate solution.) Best, lnk |
Thanks your advice.
I tried to use blocking to make the mesh, and what I can get is hexahedron. I thought tetra mesh is better, so I gave up the blocking. Do you think which one is better to get better quality? THANKS! HUIHUI |
If you become good at hexa mesh, you will always have a way to improve quality. But you may spend more time on mesh generation. Best regards, lnk |
use www.4shared.com
