[ANSYS Meshing] meshing problem due to new name selection |
July 21, 2012, 13:27 |
Rep Power: 13 |
i had to really fight it out with some issues that were coming due to inflation and finally completed the meshing successfully.
but when i tried to name it and update the mesh gave an error!! i know it is a very wierd thing to happen any solutions? thank you in advance. p.S- i cant repeat the mesh i need to name it without making any changes in the settings |
July 21, 2012, 14:38 |
Rep Power: 13 |
An error occured during sweeping while meshing the following face. Change element sizing parameters and try again.
this error is occuring is inflation of a semi cylindrical disk sweep body . i tried many max thicknesses but none work .the error geometry is coming as surface along the th path. any sggestions please very urgent |
Problem with querying the meshing database in CFX-Pre | ashtonJ | CFX | 18 | April 18, 2023 23:49 |
Stability problem due to turbulent dispersion force in a subcooled boiling model | Edy | OpenFOAM | 7 | August 10, 2011 12:00 |
[ICEM] ICEM meshing problem | xyq102296 | ANSYS Meshing & Geometry | 6 | October 28, 2010 10:09 |
problem with gambit unsymmetrical meshing | meenakshi | FLUENT | 1 | March 28, 2008 12:46 |
ICEM meshing problem | Forrest | CFX | 4 | May 25, 2005 18:37 |
