[ICEM] PRISM at different places
Old   July 20, 2012, 12:34
Default PRISM at different places
Huihui Wang
huihui is on a distinguished road
I try to make prism at the bed of the container, and around the pipe.
in the bed of the container, it is ok to be generated. but around the pipe, I can't get the prism layers. why it's like this? any method can fix it?
what i did is make the round surface to be prismed, like the bottom surface.
anything wrong?
THANKS!
HUIHUI
huihui is offline   Reply With Quote
Old   July 21, 2012, 03:43
siw
Stuart
siw will become famous soon enough
You could assign the internal surface of the hole as a PART, then set up the prism data in Part Mesh Set-Up (not forgetting to tick the prism check-box)?
siw is offline   Reply With Quote
Old   August 7, 2012, 09:44
Guiliguili
Touré is on a distinguished road
Put the boundary lines and circle in different Part when you create them. Then, select the cylinder boundary and the bed boundary as Prism in Mesh -> Part Mesh Setup.
I selected just the STATOr-BLADE boundary in the picture attached to make it prism.
Touré is offline   Reply With Quote
Getting prism to inflate into mixed tet-hex meshes Joe CFX 16 October 10, 2011 08:06
ICEM Prism Layer transition between surface with prism layers and one without TWaung ANSYS Meshing & Geometry 2 October 12, 2009 15:56
Trimmer & prism layer peresah STAR-CCM+ 6 October 6, 2009 15:39
ICEM - Prism Tool Problem carpe85 CFX 0 February 10, 2009 13:25
Icemcfd: Preventing prism inflation collisions? Joe CFX 1 July 31, 2007 10:13
